Solving Percentage Questions: 231 mg Potassium in Dandelions vs 93 mg in Lettuce
  • Thread starter Thread starter lha08
This discussion focuses on calculating the percentage difference in potassium content between dandelions and lettuce, specifically 231 mg in dandelions versus 93 mg in lettuce. The correct calculations are (231-93)/93 = 148.39% more potassium in dandelions relative to lettuce, and (231-93)/231 = 59.74% more potassium in dandelions relative to itself. The confusion arises from the need to clarify the reference point for percentage calculations. It is essential to determine whether the comparison is made relative to the amount in lettuce or dandelions.
  • Understanding of basic percentage calculations
  • Knowledge of potassium content in common vegetables
  • Ability to interpret comparative data
  • Familiarity with serving sizes of vegetables
  • Research how to calculate percentage differences in nutritional content
  • Learn about potassium requirements and sources in human nutrition
  • Explore serving size standards for vegetables
  • Investigate common misconceptions in percentage calculations
Students, nutritionists, dietitians, and anyone interested in understanding nutritional comparisons between different food sources.
lha08
So I'm drawing a complete blank on how to figure out some easy math...like given that there is 231 mg of potassium in a dandelion and 93 mg of potassium in lettuce, how much more (%wise) is there of potassium in dandelions...
i thought at first that its (93/231)*100= 40.26% but then i started second guessing myself...
(1) How much more is there in dandelion than in lettuce?
Answer: (amount in dandelion) - (amount in lettuce)
(2) What percentage is this of the amount of potassium in ...
sorry but i don't quite get what you said for (2)...
final-initial/initial = percent gain
I left the... to make clear you still had to decide whether you want to know either A or B:
A: (how much more (%wise) is there of potassium in dandelions than in lettuce) relative to the amount in lettuce.
B: (how much more (%wise) is there of potassium in dandelions than in lettuce) relative to the amount in dandelion.
like for some reason, I'm still kind of confused...like this is what I've got...
Is this right or should it be the opposite way meaning (231-93)/231= 59.74% more potassium in dandelions...?
Yes, there is "(231-93)/93 = 148.39% more potassium in dandelions" then in lettuce, relative to the amount in lettuce (that is: the amount more in dandelion than in lettuce is equal to 148.39% of the amount in lettuce)
When they ask "%-wise" it is not always clear what is meant, a percentage is always relative to something. Another correct answer would be:
There is (231-93)/231 = 59.74% more potassium in dandelions then in lettuce, relative to the amount in dandelions (that is: the amount more in dandelion than in lettuce is equal to 59.74% of the amount in dandelion)
In a way, you're comparing apples to oranges here. The only way you can compare percentages of potassium in dandelions and lettuce is to compare quantities that are comparable. You say there are 231 mg of potassium (K) in a dandelion. How big a serving of lettuce contains the 93 mg of K? Unless otherwise stated you should be comparing one dandelion with an amount of lettuce of about the same weight.
  • · Replies 20 ·
  • · Replies 36 ·
