Solving PreCalc Questions: Homework Statement & Example
  • Thread starter Thread starter GreenPrint
The discussion centers around solving the equation SQRT(3) sin theta + cos theta = 1 within the interval [0, 2π]. The original poster expresses confusion about the example provided in their homework, which outlines a method for solving similar equations by transforming them into a sine function. Despite attempts to apply the formula, the poster arrives at incorrect solutions of pi/6 and (5 pi)/6. They also share their struggles with an alternative approach involving squaring both sides of the equation, ultimately leading to further confusion. The poster seeks guidance on correctly applying the concepts to solve these types of problems.
GreenPrint
I have no idea how to do these type of problems.
-------Problem--------
Solve each equation on the interval 0 less than or equal to theta less than 2 pi
42. SQRT(3) sin theta + cos theta = 1
There is an example prior to the excersises that attempts to explain how to do these types of problems. I do not understand it...
-------EXAMPLE---------
Solve the equation on the interval 0 less than or equal to theta less than 2 pi
a sin theta + b cos theta = c (2)
where a, b, and c are constants and either a does not equal 0 or b does not equal 0.
We divide each side each side of equation (2) by SQRT(a^2 + b^2). Then
a sin theta /SQRT(a^2 + b^2) + b cos theta/SQRT(a^2 + b^2) = c/SQRT(a^2 + b^2) (3)
There is a unique angle phi, 0 less than or equal to phi less than 2 pi, for which
cos phi = a/SQRT(a^2 + b^2) and sin phi = b/SQRT(a^2 + b^2) (4)
Figure 36
http://img269.imageshack.us/img269/3002/capturenmk.jpg
See Figure 36. Equation (3) may be written as sin theta cos phi + cos theta sin phi = c/SQRT(a^2 + b^2)
or, equivalentley,
sin(theta + phi) = c/SQRT(a^2 + b^2) (5)
where phi satisfies equation (4).
If |c| > SQRT(a^2 + b^2), then sin(theta + phi) > 1 or sin(theta + phi) < -1, and equation (5) has no solution.
If |c| less than or equal to SQRT(a^2 + b^2), then the solutions of equation (5) are
theta + phi =sin^-1 c/SQRT(a^2 + b^2) or theta + phi = pi - sin^-1 c/SQRT(a^2 + b^2)
Because the angle phi is determined by equations (4), these are the solutions to equation (2).
Well I didn't understand but here is my attempt at solving the PROBLEM which is clearly wrong
-----ATEMPT AT A SOLUTION-------
I just plugged and chugged into what the book claims to be the solutions into the formula
theta + phi = sin^-1 1/SQRT(3 +1) = sin^-1 1/2 = pi/6
or
theta + phi = pi - pi/6 = (5 pi)/6
Well I'm lost so if you could guide me in some way to solve these type of problems that would be extremely appreciated... TAHNKS!
here is another atempt using a different appraoch were I get stuck yet again...
Here's what I did
SQRT(3)sinx + cosx = 1
subtract cos x from both sides
SQRT(3)sinx = 1 - cosx
squared both sides
3 sin^2 x = 1 - 2cosx +cos^2 x
replaced sin^2 x with a trig idendity
3 (1 - cos^2 x) = 1 - 2cosx + cos^2 x
multiplied out the three
3 - 3cos^2 x = 1 - 2cosx + cos^2 x
subtracted cos^2 x from both sides
3 - 4cos^2 x = 1 - 2cosx
added 2cosx to both sides
3 - 4cos^2 x + 2 cosx = 1
subtracted 1 from both sides
2 - 4cos^2 x + 2cosx = 0
factored out the 2
2( 1 - 2cos^2 x + cos x) = 0
factored out the cosx
2(1 +cosx(-2cosx + 1) = 0
2 = 0 or 1 +cosx(-2cosx + 1)=0
from which I am stuck yet again...
Also I checked the formulas that the example gave me and plugged in my two answers for theta into the original equation and did get wrong...
This is just me confirming that
pi/6 and (5 pi)/6 are wrong and that I am clearly not understanding something here
I'd take your last equation, divide 2, subtract 1, and then take the arccosine of both sides. Then keep working from there.
I tried to combine those 2 formulas but it didn't work. I tried using another case where there are 2 red balls and 2 blue balls only so when combining the formula I got ##\frac{(4-1)!}{2!2!}=\frac{3}{2}## which does not make sense. Is there any formula to calculate cyclic permutation of identical objects or I have to do it by listing all the possibilities? Thanks
Since ##px^9+q## is the factor, then ##x^9=\frac{-q}{p}## will be one of the roots. Let ##f(x)=27x^{18}+bx^9+70##, then: $$27\left(\frac{-q}{p}\right)^2+b\left(\frac{-q}{p}\right)+70=0$$ $$b=27 \frac{q}{p}+70 \frac{p}{q}$$ $$b=\frac{27q^2+70p^2}{pq}$$ From this expression, it looks like there is no greatest value of ##b## because increasing the value of ##p## and ##q## will also increase the value of ##b##. How to find the greatest value of ##b##? Thanks
