Solving Projectile Motion Problems: Intersecting Balls at Different Heights
The problem involves two balls being thrown from different heights: one from the top of a 10-storey building and the other from a second-floor window. The first ball is thrown downward with an initial speed, while the second ball is thrown upward with a significantly higher initial speed. The discussion focuses on determining the time at which the two balls intersect and the timing required for them to hit the ground simultaneously.
  • Mixed
  • Participants explore the equations of motion to find the intersection time and the conditions for both balls to hit the ground simultaneously. Some question the direction of the initial velocity for the first ball and suggest considering a reference frame in free fall for simplification.
Participants have engaged in verifying calculations and discussing the approach to the problem. Some have provided guidance on simplifying the problem by changing the reference frame, while others have expressed uncertainty about the correct method for part b of the question.
There is some confusion regarding the initial conditions and the direction of the velocities. Participants are also navigating the constraints of the problem setup, including the heights from which the balls are thrown and the respective initial speeds.
Max0007
The top of a 10-storey building (42 m) , someone throws a ball (A) down with a
initial speed of 2.5 m / s. You are on the second floor (8 m window above the ground) and
You throw a ball (B) upward with an initial speed of 22 m / s.
a) If both balls are thrown together after how much time do they intersect ?
b) It is hoped that the two balls, launched with the same speed and in the same direction , strike
the soil simultaneously. Which bullets (A or B) is to be launched first? how
time before the other ball should it be launched ?
Initial Speed for A: 2.5 m/s
height B initial: 42 m
height B final: 0 m
Initial Speed for B: 22 m/s
height B initial: 8 m
height B final: 0 m
a)
height final= height initial + Initial speed *(final time - initial time) - g/2 *(final time - initial time)^2
0=8 + 22m/s * (time) - 9.81/2 * (time)^2
0=42 + 2.5m/s * (time) - 9.81/2 * (time)^2
To find the the time when it intersect I did this:
42 + 2.5m/s * (time) - 9.81/2 * (time)^2 = 8 + 22m/s * (time) - 9.81/2 * (time)^2
and found 1.74seconds
For b)
I found at what time they both hit the ground.
0=42 + 2.5m/s * (time) - 9.81/2 * (time)^2 // A hits the ground in 3.19 secs
0=8 + 22m/s * (time) - 9.81/2 * (time)^2 // B hits the ground in 4.82 secs
I want to trow B first because it takes longer than A to hit the ground.
Now since B hits the ground in 4.82 secs I will replace 4.82 sec in this 42 + 2.5m/s * (time final - time initial) - 9.81/2 * (time final - time initial)^2 , I will replace it in time final. So I will have to find the time initial. I want A to hit the ground the same time as B.
42 + 2.5m/s * (4.82 - time initial) - 9.81/2 * (4.82- time initial)^2=0
I find 2.14 secs.
Can you guys verify that its all good please ? I really appreciate it :)
Which way was the ball thrown from the top? (Same problem in part b.)
There is an easier way to solve this. Consider a reference frame in free fall.
Max0007 said:
For b)
"Which way was the ball thrown from the top? (Same problem in part b.)"
downward so its -2.5m/s
But for part b) I realized I did not do the right thing. I don't know how to actually do it ;(
Right. The easier way, as I wrote, is to consider a reference frame in free fall. In that frame, each ball has a constant velocity. So how long do they take to meet?
Quite so.
You started out well, finding the time each takes. From there it was an extremely short step to the answer, but you wandered off course.
Quite so.
Time B - Time A? only that :O
That'll do it.
  • · Replies 21 ·
  • · Replies 38 ·
