Solving RC Circuit Problem Homework
5 replies · 5K views
majormaaz
Consider the circuit in the figure below, in which V = 85 V, R = 40 , and the switch has been closed for a very long time.
(a) What's the charge on the capacitor?
(b) The switch is opened at t = 0 s. At what time has the charge on the capacitor decreased to 10% of its initial value?
[Here's the link for the picture if it doesn't come up]
http://www.webassign.net/knight/p31-77alt.gif
C = Q/V
V = IR
Q = C*EMF*e^(-t/RC)
For part (a), I thought that since the circuit's been connected like that for a long time, the voltage across the capacitor would be the same as the battery's voltage - i.e. 85 Volts. From there, a simple Q = CV would yield 1.7 e -4 C = 170 μC, but that's not right.
For part (b), I was thinking that since it's a parallel circuit, I'd have to use Kirchoff's Law and the Loop Rule to get those 2 loop equations and the Junction equation, but I'm not sure as to if there's another method to get to the answer.
I would appreciate any help!
C = Q/V
V = IR
Q = C*EMF*e^(-t/RC)
(The image shows up just fine!)
For part (a):
After a long time, the capacitor is fully charged, so no current flows through it or the 10Ω resistor. So there is 0 voltage drop across the 10Ω resistor.
However, current does flow through the 60Ω and 40Ω (R) resistors. Thus they act as a voltage splitter, and C is in parallel with R .​
I think you're saying that the voltage across C would be the same potential difference as the voltage drop across resistor R. But I don't get how that would work if the capacitor was fully charged - I mean, after a long time, I can see why there'd be no current in that branch, but wouldn't the capacitor have charged up to the voltage of the battery by then (and not the resistor)?
Thanks for the help! I did get both answers with your help, but I'd still like to understand why the capacitor would charge up to (I)*40 Ω instead of the full battery voltage.
The potential difference across the capacitor cannot go higher than the potential difference available at the nodes where it connects.
To find the steady-state potential that a capacitor will achieve, remove the capacitor from the circuit and find the open-circuit voltage at the open terminals where it was connected.
I will keep this in mind. Thanks!
