Solving second-order linear ODE with initial conditions y'' + 4y' + 3y = 0
darryw
Solve the following initial value problem. Sketch the solution and describe its behavior
as t increases.
y'' + 4y' + 3y = 0
y(0) = 2
y'(0) = -1
1st i solved the characteristic:
r^2 + 4r + 3 = 0
r = -1
r = -3
then the general solution is;
y = c_1e^-x + c_2e^-3x
also..
y' = -c_1e^-x - 3c_2e^-3x
so after i plug in the initial values i get 2 equations and 2 unknowns..
c_1 + c_2 = 2
-c_1 - 3c_2 = -1
c_1 = 5/2
c_2 = -1/2
so the solution with initial conditions (is this called "particular solution?) is:
y = (5/2)e^-x - (1/2)e^-3x
is this much correct before i describe the equations behavior? thanks a lot
as t increases.
y'' + 4y' + 3y = 0
y(0) = 2
y'(0) = -1
r^2 + 4r + 3 = 0
r = -1
r = -3
also..
c_1 + c_2 = 2
-c_1 - 3c_2 = -1
c_1 = 5/2
c_2 = -1/2
You've done all the hard work. Checking the solution to an initial value problem is easy in comparison. For your solution, y = (5/2)e-x - (1/2)e-3x, is it true that y(0) = 2 and y'(0) = -1? If so, then your solution satisifies the initial conditions, mean that the solution function goes through (0, 2) and its slope there is -1.
For your solution function, is it true that y'' + 4y' + 3y = 0? If so, then your solution satisifies the differential equation, and you're home free.
