Solving Sine Rule Question: Angle B & A in Triangle ABC
  • Context:
  • Thread starter Thread starter ai93
    Sine
4 replies · 3K views
ai93
I understand how to use the Sine rule, but I think I may get stuck halfway through!
My questions is:
In a Triangle ABC the angle at C is 48.15 degrees, side AB is 15.3m and side AC is 17.6m.
Calculate the size of angle B and angle A, giving all possible solutions, in degrees accurate to 1 d.p.
I used the Sine rule.
$$\frac{SinB}{17.6}=\frac{Sin(48.15)}{15.3}$$
$$\therefore$$$$SinB=\frac{15.3}{Sin(48.15)x17.6} = 0.86$$
so, B=$$Sin^{-1}(0.86)$$
B= 59 degrees.
I understand up to here, but in the solution B can = 59 or 120.9 degrees. Where I am not sure where 120.9 comes from!
Therefore I can only solve for B but not for A. Any help?
Mathematics news on Phys.org
There are two angles for which:
$$\sin(B)\approx0.86$$ and $$0^{\circ}<B<180^{\circ}$$
You found the first quadrant angle, but recall the identity:
$$\sin\left(180^{\circ}-\theta\right)=\sin(\theta)$$
Therefore, we also find that it may be possible that:
$$B\approx180^{\circ}-\arcsin(0.86)\approx120.68^{\circ}$$
Now, since:
$$120.68+48.15=168.83<180$$
We know there are two possible triangles that satisfy the given conditions. You can read more about the ambiguous case here:
Law of sines - Wikipedia, the free encyclopedia
Now, since:
I fairly understand..
So, since we found out the first quadrant, angle B which is 59 degrees.
We can say B $$\approx180 - sin^{-1}(0.86)\approx120.86$$
Can I ask when do we know that the angle can have two solutions?
We have angle C as 48.15, angle B can be either 59 or 120. Or can angle A be 168.
Sorry, abit confused!
We know there can be two triangles because:
Because the sum of the given angle and the larger possibility is less than $180^{\circ}$, we know this leaves room for the third angle.
So, when $\angle B\approx 59.32^{\circ}$ then $\angle A\approx180^{\circ}-\left(48.15+59.32\right)^{\circ}$ and when $\angle B\approx 120.68^{\circ}$ then $\angle A\approx180^{\circ}-\left(48.15+120.68\right)^{\circ}$. This is because the sum of the three interior angles of a triangle is always $180^{\circ}$.
Thanks! Makes a lot more sense now :D
