Solving Supremum Question: Is 4 the Right Answer?
  • Context: Graduate
  • Thread starter Thread starter Cankur
    Supremum
3 replies · 2K views
Cankur
Hello!
I had a test in which the question that I will present here was asked. I got no points for my attempt at a solution. Do you think that I was still on the right track and that I deserve partial points? Here is the question:
"A number M is said to be an upper bound to a set A if M [itex]\geq[/itex] x for every x[itex]\in[/itex] A. A number S is said to be supremum of a set A if S is the smallest upper bound to A.
Assume that:
A = {(4n2)/(n2+1) : n [itex]\geq[/itex]0 is an integer}.
Show that supremum of A is 4."
And here is what I wrote as an answer (not verbatim, but translated from another language):
"Since n does not have an upper limit, it can go toward infinity. In this case:
A = lim (n [itex]\rightarrow[/itex] [itex]\infty[/itex]) (4n2)/(n2+1)=[itex]\infty[/itex]/[itex]\infty[/itex]. This shows that we can use l'hopital's rule. After using l'hopital's rule twice we get that A = 4. In other words, this gives us supremum. Since n always can be even bigger, this is just the smallest upper bound.
Answer: By using l'hopital's rule twice, I have shown that supremum A is 4."
Out of the possible 4 points that one could get on that question, I got 0. Was it justified?
Thanks in advance!
Essentially, what you showed was that the limit, as n goes to infinity, of that sequence is 4. That does NOT prove that 4 is the supremum. For example, the limit of 1/n, as n goes to infinity is 0 but 0 is definitely not the supremum!
Here, you would also have to show that your sequence is increasing and you did not do that.
Oh, and I certainly would not have used L'Hopital's rule for that limit: just divide both numerator and denominator by n2.
In simple terms: (4n2)/(n2+1)=4/(1+1/n2) < 4.
As n becomes infinite limit is 4. Another way is assume the sup = a < 4, then you can find a large enough n so the expression > a: contradiction.
Thanks for the answers! I see that there were quite essential things that I missed. But you don't think I deserve some points for my answer?
