Solving System of PDEs: Analytical Methods & Solutions
  • Context: Graduate
  • Thread starter Thread starter satu
    Pdes
This discussion focuses on solving a system of two partial differential equations (PDEs) related to hydrodynamic stability. Participants emphasize that there are no universal methods for solving all PDE systems, and they highlight the importance of boundary conditions and the correct formulation of the problem. The suggested approach involves using normal modes and linear stability analysis, specifically substituting functions of the form (\theta, \psi) = (\Theta e^{k_nx}\sin(n\pi y), \Psi e^{k_nx}\sin(n\pi y)). The solution requires determining the eigenvalues from a generalized eigenvalue problem defined by the matrix M(k_n).
  • Understanding of Partial Differential Equations (PDEs)
  • Familiarity with linear stability analysis techniques
  • Knowledge of boundary conditions in fluid dynamics
  • Experience with eigenvalue problems and matrix theory
  • Study the method of normal modes in the context of PDEs
  • Learn about linear stability analysis in fluid dynamics
  • Explore generalized eigenvalue problems and their applications
  • Research boundary condition types such as no-slip and stress-free conditions
Researchers, mathematicians, and engineers working in fluid dynamics, particularly those dealing with stability analysis of hydrodynamic systems and partial differential equations.
satu
TL;DR
Methods to find solutions of system of PDEs
HI
HI! While trying to solve problem in Hydrodynamic stability I have got a system of Two Partial Diffential equations :
Can anyone help me to solve this analytically? Is there any general method to solve system of PDEs?
Can you clarify your notation? E.g., does ##\theta_{1x},\psi_{1x}## mean ##\partial\theta_{1}/\partial x,\partial\psi_{1}/\partial x##?
nothing about boundary conditions
nothing about the domain
nothing about functional spaces
nothing to speak about
no general methods to solve everything
Yup. You may consider ## \psi ## inplace of ##\psi_1## and ## \theta ## in place of ##\theta_{1}##
nothing to speak aboutno general methods to solve everything
B.C's : ## \psi_{1} = \theta_{1} = 0 ## at both ## y=0## and ##y=1##.
##\nabla^2 = \partial^2/\partial x^2 + \partial^2/\partial y^2 ##
Both ##\psi_{1} ## and ##\theta_{1}## are functions of x and y.
this does not make sense: your solutions are defined up to ##+c_1 +c_2y##
satu said:
TL;DR Summary: Methods to find solutions of system of PDEs
HI
This is a linearised stability problem, so you are looking for normal modes. Your assumption, in view of the boundary conditions, is that <br /> (\theta, \psi) = (\Theta e^{k_nx}\sin( n\pi y), \Psi e^{k_nx}\sin (n \pi y)) for constant (\Theta, \Psi) and positive integer n. If k_n has strictly positive real part, then the disturbance will grow as x \to \infty. If k_n has strictly negative real part, the disturbance will instead grow as x \to -\infty.
Subsituting these into the PDEs will give you a linear system of the form <br /> M(k_n)\begin{pmatrix} \Theta \\ \Psi \end{pmatrix} = 0 for some matrix M(k_n). For this to have non-zero solutions, k must satisfy \det M(k_n) = 0. (This is a generlized eigenvalue problem with (\Theta, \Psi) being an eigenvector corresponding to the generalized eigenvalue k_n.)
The general solution, if desired, can then be obtained as a linear combination of normal modes, but for the linear stability analysis we only need the sign of the real part of k_n.
anyway
What definition of stability do you mean? As for me I heard about stability in evolution systems only. I do not see any evolution here and I do not see any uniqueness. I actually suspect that the boundary conditions still have not been formulated correctly but maybe x is such a new notation for time. Who knows.
Indeed, it's unlikely that ##x## is supposed to be time since the OP states that ##\nabla^2 = \partial^2/\partial x^2 + \partial^2/\partial y^2##, which is the 2D Laplacian, not the 2D wave-operator.
wrobel said:
anyway
The OP did state "While trying to solve problem in Hydrodynamic stability ...". However, since the OP hasn't told us which problem they are trying to solve or how they derived this system, we can but speculate.
I did misinterpret the situation in my earlier post.
The system of PDEs looks like what one gets for marginal stability (\partial_t = 0) of small disturbances to the static solution of the equations for incompressible Rayleigh-Benard convection in two dimensions, with \psi being the streamfunction and \theta the departure of the (scaled) temperature from the static solution; R_0 is then the Rayleigh number.
The correct approach is to first set (\theta, \psi) = (\Theta(y), \Psi(y))e^{ikx} to obtain a system of ODEs for the dependence on y; we are looking for the wavenumber k at which the static solution first becomes unstable - hence the assumption of marginal stability.
We are missing some boundary conditions - we need either \psi_y = 0 (no-slip) or \psi_{yy} = 0 (stress-free) at each boundary.
  • · Replies 0 ·
