Solving the differential equation (e^y + 1)^2 e^{-y} dx + (e^x + 1)^3 e^{-x} dy = 0
  • Thread starter Thread starter basty
    Integration
22 replies · 3K views
basty
##(e^y + 1)^2 e^{-y} dx + (e^x + 1)^3 e^{-x} dy = 0##
##(e^{2y} + 2 e^y + 1) e^{-y} dx + (e^{3x} + 3e^{2x} + 3e^x + 1) e^{-x} dy = 0##
##(e^{2y - y} + 2 e^{y - y} + e^{-y}) dx + (e^{3x - x} + 3e^{2x - x} + 3e^{x - x} + e^{-x}) dy = 0##
##(e^{y} + 2 e^{0} + e^{-y}) dx + (e^{2x} + 3e^{x} + 3e^{0} + e^{-x}) dy = 0##
##(e^{y} + 2 (1) + e^{-y}) dx + (e^{2x} + 3e^{x} + 3 (1) + e^{-x}) dy = 0##
##(e^{y} + 2 + e^{-y}) dx + (e^{2x} + 3e^{x} + 3 + e^{-x}) dy = 0##
##(e^{y} + e^{-y} + 2) dx + (e^{2x} + 3e^{x} + e^{-x} + 3) dy = 0##
##(e^{2x} + 3e^{x} + e^{-x} + 3) dy = - (e^{y} + e^{-y} + 2) dx##
## - \frac{1}{e^{y} + e^{-y} + 2} dy = \frac{1}{e^{2x} + 3e^{x} + e^{-x} + 3} dx##
## - \int \frac{1}{e^{y} + e^{-y} + 2} dy = \int \frac{1}{e^{2x} + 3e^{x} + e^{-x} + 3} dx##
It is a difficult integration. What next?
The only thing that I can see here is [itex]\frac{1}{e^y+e^{-y}+2}=\frac 1 4 \sec^2 \frac y 2[/itex].
You mean sech(), right?
How do you get ##\frac{1}{e^y+e^{-y}+2}=\frac 1 4 \sec^2 \frac y 2##?
I know that ##sech \ x = \frac{2}{e^x + e^{-x}}##.
I know that ##sech \ y = \frac{2}{e^y + e^{-y}}##.
[itex]sech x=\frac{2}{e^x+e^{-x}} -^{x=\frac{y}{2}}\rightarrow sech \frac y 2=\frac{2}{e^{\frac y 2}+e^{-\frac y 2}} \rightarrow sech^2 \frac y 2=\frac{4}{e^{y}+e^{-y}+2}[/itex]
Shyan said:
[itex]sech x=\frac{2}{e^x+e^{-x}} -x=\frac{y}{2}\rightarrow sech \frac y 2=\frac{2}{e^{\frac y 2}+e^{-\frac y 2}} \rightarrow sech^2 \frac y 2=\frac{4}{e^{y}+e^{-y}+2}[/itex]
Why ##sech \ x = \frac{2}{e^x + e^{-x}} - x##?
And why it equal to ##\frac{y}{2}##?
The correct one is ##sech \ x = \frac{2}{e^x + e^{-x}}##, not ##\frac{2}{e^x + e^{-x}} - x##.
What this -x variable mean?
Oh...I meant to be a little fancy but looks like it was a bad idea. I meant take [itex]sech x=\frac{2}{e^x+e^{-x}}[/itex] and then set [itex]x=\frac y 2[/itex].
You said ##sech \ \frac{y}{2} = \frac{2}{e^{\frac{y}{2}} + e^{-\frac{y}{2}}}##
##= \frac{2}{e^{\frac{y}{2}} + \frac{1}{e^{\frac{y}{2}}}}##
##= \frac{2}{\frac{(e^{\frac{y}{2}})^2 + 1}{e^{\frac{y}{2}}}}##
##=\frac{2 e^{\frac{y}{2}}}{(e^{\frac{y}{2}})^2 + 1}##
##=\frac{2 e^{\frac{y}{2}}}{(e^{\frac{y}{2}}. \ e^{\frac{y}{2}}) + 1}##
##=\frac{2 e^{\frac{y}{2}}}{e^{\frac{y}{2} + \frac{y}{2}} + 1}##
##=\frac{2 e^{\frac{y}{2}}}{e^{\frac{y + y}{2}} + 1}##
##=\frac{2 e^{\frac{y}{2}}}{e^{\frac{2y}{2}} + 1}##
##=\frac{2 e^{\frac{y}{2}}}{e^{y} + 1}##
Please explain. I am really confuse.
When you write this
exdx/(ex + 1)3 = - eydy/(ey + 1)2
isn't each side easily recognised as derivative of something?
Or if you don't recognize the derivatives, try the obvious substitutions.
epenguin said:
When you write this
##\frac{e^x dx}{(e^x + 1)^3} = \frac{-e^y dy}{(e^y + 1)^2}##
I still don't get it. Give me more clue please.
Vela gave you a clue in post #12. Try it.
I shall integrate the left side (the x variable) first. If using the substitution method, which one should be substituted?
Let ##u = e^x## or ##u = e^x + 1##?
Try them both. You should see that one is slightly better than the other.
(1)
Let ##u = e^x + 1## then ##\frac{du}{dx} = e^x## or ##du = e^x dx##
##\int \frac{e^x dx}{(e^x + 1)^3}##
##= \int \frac{1}{u^3}du##
##= \ln |u^3| + c##
##= \ln (e^x + 1)^3 + c##
(2)
Let ##u = e^y + 1## then ##\frac{du}{dy} = e^y## or ##du = e^y dy##
##\int \frac{-e^y dy}{(e^y + 1)^2}##
##= - \int \frac{e^y dy}{(e^y + 1)^2}##
##= - \int \frac{1}{u^2}du##
##= - \ln |u^2| + c##
##= - \ln (e^y + 1)^2 + c##
From (1) and (2), I get:
##\int \frac{e^x dx}{(e^x + 1)^3} = \int \frac{-e^y dy}{(e^y + 1)^2}##
##\ln (e^x + 1)^3 + c = - \ln (e^y + 1)^2 + c##
Is it correct?
(1)
##= \ln |u^3| + c##
(2)
Is it correct?
That is certainly not correct. What is:
$$\int u^{-3} \space du$$
Good catch, Zondrina. I totally missed that he was using this integration "rule" (in quotes because it's not an integration rule):
##\int \frac{dx}{f(x)} = ln|f(x)| + C##
Thank you for the correction.
Let I correct the mistake:
(1)
##= \int u^{-3} du##
##= \frac{1}{-3+1}u^{-3+1} + c##
##= \frac{1}{-2}u^{-2} + c##
##= - \frac{1}{2}(e^x + 1)^{-2} + c##
(2)
##= - \int u^{-2} du##
##= - \frac{1}{-2+1} u^{-2+1} + c##
##= - \frac{1}{-1} u^{-1} + c##
##= u^{-1} + c##
##= (e^y + 1)^{-1} + c##
##- \frac{1}{2}(e^x + 1)^{-2} + c = (e^y + 1)^{-1} + c##
Is it correct?
That looks better. In the last line you have this:
You shouldn't use the same constant on both sides.
##- \frac{1}{2}(e^x + 1)^{-2} + c_1 = (e^y + 1)^{-1} + c_2##
Or you can combine both constants into a third constant, like so:
##- \frac{1}{2}(e^x + 1)^{-2} = (e^y + 1)^{-1} + c##
OK.
It's on right lines at least, but not quite correct is you have written the same integration constant on both sides which is tantamount to an integration constant of 0, so that is conceptually not quite correct. You only need one integration constant - I hope clear why.
Apart from that you don't ever need to ask us whether an integration is correct - you can tell us rather because you can always check correctness by differentiation.
Also (Polya Principle) in doing that you might notice how you might have arrived at the result a bit faster, ideally, though getting there somehow is the most important.
(posting overlap)
