Solving the Differential Equation for Unique Solution in Region
5 replies · 9K views · last reply
Lancelot59
The given problem for multiple differential equations (not in a system) is: "Determine a region of the xy-plane for which the given differential equation would have a unique solution whose graph passes through a point (x0,y0) in the region."
I'm not entirely sure what to do with this. Looking at the function:
[tex]\frac{dy}{dx}=y^{\frac{2}{3}}[/tex]
I found the unknown function to be:
[tex]y=(\frac{x}{3})^3[/tex]
And I have verified that it is a solution.
Now the books says the answer is: "half-planes defined by either y>0 or y<0"
I'm not sure how this solution works. Could someone please explain it to me?
I also don't understand why y=0 isn't valid. I can see y=0 satisfying this equation:
0=0
Yes, y=0 is a solution that passes through (0,0). y=(x/3)^3 is also a solution that passes through (0,0). So there is no unique solution if the initial point (x0,y0)=(0,0). What about (x0,y0) being a point besides (0,0)? I thinks that's what they are asking.
the DE is separable
integrating both sides gives
[tex]\int dyy^{-\frac{2}{3}}=\int dx[/tex]
[tex]\frac{1}{3}y^{\frac{1}{3}}=x+c[/tex]
[tex]\frac{1}{3}y^{\frac{1}{3}}=(\frac{x+c}{3})^3[/tex]
this is a family of solutions given by c
now consider whether the following is a solution:
[itex]for \ \ \ \ x \leq 0, \ \ \ \ \ \ y(x) = (\frac{x}{3})^3[/itex]
[itex]for \ \ 0< x \leq 1, \ \ y(x) = 0[/itex]
[itex]for \ \ \ \ 1< x, \ \ \ \ \ \ y(x) = (\frac{x-1}{3})^3[/itex]
lanedance said:
the DE is separable
So you are only using solutions which do not make the equation equal to zero? Is the term homogenous applicable to that case?
On the contrary, Lancelot59's solution explicitely includes y= 0. That's why he can construct an infinite number of solutions such that y(0)= 0.
The "fundamental existence and uniqueness theorem for first order differential equations" says that the problem dy/dx= f(x,y), y(x0)= y0 has a unique solution if there is some neighborhood about (x0,y0) such that f(x,y) is continuous and f(x,y) is "Lipschitz" in y ("differentiable with respect to y is a simpler, sufficient but not necessary condition) in that neighborhood.
Here, [itex]f(x,y)= y^{2/3}[/itex] is continuous in any neighborhood of (0,0) but [itex]f_y= (2/3)y^{-1/3}[/itex] does not exist at (0, 0) so the function is not Lipschtz there.
We can guarantee a unique solution on any neighborhood that does NOT include the x-axis but not in any neighborhood that does.
I see, so the trick is to differentiate the original differential equation with respect to the "dependent" (Y in this case) variable, and see where solutions for it are valid?
