Solving the Mystery of the 2: JD Jackson on Classical Electrodynamics
  • Context: Graduate
  • Thread starter Thread starter Berko
    Example Jackson
In the discussion regarding JD Jackson's Classical Electrodynamics, the method of images is applied to a grounded conducting sphere with an external charge q. The calculation of force on a small patch of area da is debated, specifically the factor of 2 in the expression (sigma^2/2epsilon_nought)da. The resolution lies in the application of Gauss's Law, which reveals that the electric field (E) is indeed sigma/2epsilon_nought due to the unique configuration of the conductor, where the inner electric field is zero, resulting in all field lines emanating from the outer surface.
  • Understanding of Gauss's Law in electrostatics
  • Familiarity with surface charge density concepts
  • Knowledge of electric field calculations for conductors
  • Basic principles of classical electrodynamics
  • Study the derivation of electric fields using Gauss's Law in various geometries
  • Explore the implications of the method of images in electrostatics
  • Investigate the behavior of electric fields in conductors under different charge distributions
  • Review advanced topics in classical electrodynamics, focusing on boundary conditions
Students and professionals in physics, particularly those focusing on electromagnetism, as well as educators seeking to clarify concepts related to electric fields and conductors.
Berko
On page 60 of his 3rd edition of Classical Electrodynamics, he discusses the method of images applied to a grounded conducting sphere with a single charge q outside it.
Near the end of the problem, he calculates the force on a small patch of area da as (sigma^2/2epsilon_nought)da.
Now, it seems to me that the force should be the E field at that point times the charge of the patch...i.e.
dF = (sigma/epsilon_nought)*(sigma da).
Where does the factor of 2 come from?
Thank you.
The E field of a surface charge density is calculated by applying Gauss's Law. The usual situation is symmetrical -- half the E field comes out of each side of the surface. However in this case E=0 on the inner side, so all of the E has to come out the outer side, and is consequently twice the usual value.
But, that's exactly my point. The E field SHOULD be sigma/epsilon_nought...but it IS sigma/2epsilon_nought.
I'm having a thought.
Can it be due to the fact that the electric field (sigma/epsilon_nought) is due to the entire surface and we are only interested in the field the REST of the surface produces at the surface patch under consideration?
So, here's what I came up with. Would love confirmation.
The E field is generally sigma/2epsilon. Since it's a conductor, the E field is sigma/epsilon. So, the rest of the conductor must be supplying the needed E field to cancel the inside E field and reinforce the outside E field. How much cancellation and reinforcing is there? You guessed it. E/2epsilon.
So, the E field provided by the rest of the conductor is E/2epsilon.
Tada?
Weeee!
19K
18K
