How to solve for the work done by a force on an object in the x direction?
  • Thread starter Thread starter chocolatelover
    Work
To calculate the work done by the force F(2xi + 5yi)N on an object moving in the x direction from the origin to x=4.96m, the integral of the force must be evaluated. The correct approach involves recognizing that there is no displacement in the y direction, leading to a focus solely on the x component. The integral simplifies to W = integral from 0 to 4.96 of (2x)dx, resulting in a total work of 41.6J. Several participants noted errors in the initial calculations and emphasized the importance of correctly applying the dot product in this context. Ultimately, the discussion highlights the need for careful evaluation of integrals in physics problems.
chocolatelover
"work" problem
A force F(2xi+5yi)N acts on an object as it moves in the x direction from the origin to x=4.96m. Find the work W=integral vector F(dr) done by the force on the object
integral 0 to 4.96 (2xi+5yi)N=2x^2/2|0 to 4.96=24.6
integral 5yi=5y^2/2=5(4.96)/2=61.5
61.5+24.6=
86.1
Could someone please tell me if this is correct?
Thank you very much
Incorrect. There's no displacement in the y, that is, j direction.
Judging by your other posts on related topics, I would recommend another thorough reading up on this chapter.
Would it be like this?
Integral (2xi+5yj)(idx)|0 to 4.96=
integral 0 to 4.96(2x)dx=
2xx|0 to 4.56=
2x^2|0 to 4.56=
41.6
Work done in the y direction=0
Total work=41.6J
Thank you
Integral of 2x is not 2x^2. Might want to recheck that.
It's a dot product: (2xi+5yj).(idx)
2xx|0 to 4.56=
2x^2|0 to 4.56=
41.6
(Why did it become 4.56?)
Antiderivative of 2x is 2x^2/2.
Correct your calculation.
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
