Solving this Linear Differential Equation?
4 replies · 2K views
τheory
Find the general solution to this differential equation:
[itex]\frac{dy}{dx}+18x^{17}y=x^{18}[/itex]
Use the variable [itex]I[/itex] for replacing [itex]\int e^{x^{18}} dx[/itex]
2. The attempt at a solution
I've solved the differential equation using integrating factors and obtained the following result:
[itex]y=\frac{\int e^{x^{18}}x^{18} dx + C}{e^{x^{18}}}[/itex]
My problem is using the variable [itex]I[/itex] for replacing the [itex]\int e^{x^{{18}}} dx[/itex]. How am I suppose to do this with [itex]x^{18}[/itex] inside the integral?
You need to group characters using { } in LaTeX.
[tex]\frac{dy}{dx}+18x^{17}y=x^{18}[/tex]Use the variable [itex]I[/itex] for replacing [itex]\int e^{x^{18}}\,dx[/itex]
[tex]y=\frac{\int e^{x^{18}}x^{18}\,dx + C}{e^{x^{18}}}[/tex]My problem is using the variable [itex]I[/itex] for replacing the [itex]\int e^{x^{18}}\,dx[/itex]. How am I suppose to do this with x^18 inside the integral?
You can't. You want to integrate by parts now.
Are you familiar with the product rule?
(f*g)' = f'g + g'f
I am not following what you are doing at all...
You already got the integrating factor [tex]e^{x^18}[/tex], why do you have [tex]\int e^{x^18} dx[/tex]?
Okay well I did try using integration by parts after I obtained the general solution, but didn't get far as I got this:
[itex]\int e^{x^{18}}x^{18}dx[/itex]
[itex]u = x^{18}[/itex]
[itex]du = 18x^{17} dx[/itex]
[itex]dv = e^{x^{18}} dv[/itex]
[itex]v = \int e^{x^{18}} dv[/itex]
[itex]uv - \int v du[/itex]
[itex]x^{18}\int e^{x^{18}} dv - \int[ \int e^{x^{18}} dv] 18x^{17} dx[/itex]
At this point, how am I suppose to utilize the substitution of [itex]\int e^{x^{18}}dx[/itex] with [itex]I[/itex]? In other words, how do I input the general solution into the website without inputting integrals? Since the website doesn't recognize integral signs, which is why it's asking me to use [itex]I[/itex] for every [itex]\int e^{x^{18}}dx[/itex] I encounter.
To the flyingpig's question, I need to use the variable "I" because it says to do so in the online problem that I'm doing.
Try using u=x and [itex]dv=x^{17}e^{x^{18}}\,dx[/itex].
