Solving Trigonometry Equations
  • Thread starter Thread starter johnstobbart
    Trigonometry
11 replies · 3K views
johnstobbart
My trig is really rusty and I've been trying to figure out why the answer is what it is:
Find all solutions of the following equation:
sin2 x + cos x - 1.
Just the identity:
sin2 θ + cos2 θ = 1
The sin2 x is in the way, so I substitute 1 - cos2 x in it's place to get:
(1 - cos2 x + cos x - 1 = 0
The ones are removed and cos x is common, so:
cos x(-cos x + 1) = 0
This means that:
cos x = 0 or cos x = -1
From the unit circle, we get:
cos x = ∏/2 or cos = ∏
Here is where I get confused:
I know we need to make this true for all intervals so:
cos x = 0 whenever x = ± ∏/2 + 2k∏ or,
cos x = -1 whenever x = ± ∏ + 2k∏ for any integer k.
That's my final answer. According to my textbook, It's wrong, but I have no idea why. The textbook gives the final answer as:
cos x = 0 whenever x = ∏/2 + 2k∏ or,
cos x = -1 whenever x = ∏ + 2k∏ for any integer k.
Is it wrong that x = ± ∏/2 or x = ±∏?
sin2 x + cos x - 1.
Just the identity:
sin2 θ + cos2 θ = 1
This means that:
Check the piece in red.
By the way, x = ± ∏ + 2k∏ means the same x values as x = ∏ + 2k∏.
If you take n=k-1 then - ∏ + 2k∏=∏+2(k-1)∏=∏+2n∏.ehild
Thanks for the correction.
I see now. It's not wrong, just redundant.
Thanks a lot for your help.
Yes, but the solution is not correct. -cosx+1=0 does not mean cosx=-1.
ehild
Yes. - cos x + 1 = 0 is supposed to be cos x = 1, right?
Yes. So x=?
ehild
Sorry for the late reply. Things have been hectic.
x = 0, I think.
x = 0, I think.
Come on, you're learning to provide all the solutions here! What else does x equal?
x = 0 whenever x = ∏/2 + 2∏k or
x = 1 whenever x = 2∏ + 2∏k for any integer k.
Was there a mistake in the textbook when it said cos x = -1 whenever x = ∏ + 2k∏ for any integer k.
I believe you were meant to say
[itex]\cos(x)=0[/itex] whenever x=...
as opposed to x=0.
Now, you're nearly correct. Take a look at the graph of [itex]y=\cos(x)[/itex] and you should notice that while it touches its extreme values of -1 and 1 only once every [itex]2\pi[/itex] units, it cuts everything else in between twice every [itex]2\pi[/itex] units. It cuts the y-axis (or cos(x)=0) every [itex]\pi[/itex] units, so your answer should be
[itex]\cos(x)=0[/itex] whenever [itex]x=\frac{\pi}{2}+\pi k[/itex] which you can also represent (and should become familiar with) the factorized form [itex]x=\pi(\frac{1}{2}+k)[/itex]
Also, for [itex]\cos(x)=1[/itex], your answer of [itex]x=2\pi+2\pi k[/itex] is a convoluted way of saying [itex]x=2\pi k[/itex] which is the same thing. Do you see why?
Yes, I did mean cos (x) = 0 whenever x = ...
I see it now. Trig has never been my strong point and I'll make sure to practise it some more, especially the basics.
Thanks a whole lot for being so patient Mentallic and ehild.
