Solving Vector Potential: Calculating Magnetic Field & Difficulties
The discussion revolves around calculating the magnetic field from a given vector potential in the context of electromagnetism. The original poster presents a vector potential and seeks to derive the corresponding magnetic field, while also exploring the divergence of the vector potential.
  • Participants discuss the use of cylindrical coordinates for simplifying calculations related to the vector potential and magnetic field. Questions arise regarding the conversion process and the implications of symmetry in the problem.
Participants are actively engaging with the mathematical derivations and exploring different coordinate systems. Some have provided guidance on using cylindrical coordinates, while others are questioning the necessity and implications of this choice. There is a recognition of the ease of calculation in cylindrical coordinates compared to Cartesian coordinates.
There are ongoing discussions about the assumptions underlying the use of cylindrical coordinates, as well as the physical interpretation of the derived magnetic field in relation to current configurations. Participants are also addressing the potential for confusion regarding the notation and expressions used in the calculations.
Gustav
Consider the vector potential
A = C ln( (x^2+y^2)/z^2 ) \hat{z}
a) Determine the B-field for this potential. Describe a situation that gives a B-field of that shape.
b) Calculate \nabla \cdot A
c) Give a vector potential in coulomb gauge, A’, which gives the same B as in the a-task.
B = \nabla x A
My solution for the vector potential ##A=2Cln\frac{x^2+y^2}{z^2} \hat{z}## is:
a) I used the following formula to calculate the magnetic field
$$ \mathbf{B} = \nabla \times \mathbf{A} = \left( \frac{dA_z}{dy} - 0 \right) \hat{x} + \left( 0 - \frac{dA_z}{dx} \right)\hat{y} + 0 \hat{z} = \frac{dA_z}{dy} - \frac{dA_z}{dx} = 2C \frac{x}{x^2+y^2} \hat{x} - 2C \frac{y}{x^2+y^2} \hat{y}. $$
How should I describe a situation with this magnetic field here?
b) I just did the calculation of the formula and got a non-zero value:
$$ \nabla \cdot \mathbf{A} = \left( \frac{d}{dx}, \frac{d}{dy}, \frac{d}{dz} \right) \cdot \mathbf{A} = \frac{d\mathbf{A}}{dx} + \frac{d\mathbf{A}}{dy} + \frac{d\mathbf{A}}{dz} = 2C \left( \frac{y}{x^2+y¨2} + \frac{x}{x^2+y^2} - \frac{1}{z} \right) $$
c) I was having problem solving this part, I was thinking about using the same formula in question a) ##\mathbf{B} = \nabla \times \mathbf{A'}## and solve for ##\mathbf{A'}## since I have a known ##\mathbf{B}##, but then I realized it is too difficult to solve it. I also thought mathematically that this expression ##\mathbf{A'} = Cln(x^2+y^2)\hat{z}## could give us the same value of B as in the a-task. But this is still not solving the problem correctly. What should I do?
From the looks of it, you should convert to cylindrical coordinates. Look up the del operator if you don't know it in cylindrical coordinates.
How should I convert to cylendrical form? Do you mean re-write ##\mathbf{A}## in cylderincal form or re-do the whole calculation?
Also, why should it be cylendrical?
Yes, that's what I mean. Find its form here. It should be cylindrical because that is its symmetry.
Also what do you mean by its symmetry? What is its symmetry?
Okay, so for the part where the curl is I need to calculate in this form:
$$ \nabla \times A = \left[ \frac{1}{s} \frac{\partial A_z}{\partial \phi} - \frac{\partial A_\phi}{\partial z} \right]\hat{s} + \left[ \frac{\partial A_s}{\partial z} - \frac{\partial A_z}{\partial s} \right]\hat{\phi} + \frac{1}{s} \left[ \frac{\partial s A_\phi}{\partial s} - \frac{\partial A_s}{\partial \phi} \right] \hat{z} = \frac{1}{s} \frac{\partial A_z}{\partial \phi}\hat{s} - \frac{\partial A_z}{\partial s} \hat{\phi} $$
How am I going to derivate ##A_z## with respect to ##\phi## or ##s##?
First, you need to write ##A_z## as a function of ##r##, ##\phi## and ##z##? Do that first, then take the partial derivatives.
Okay, I tried to re-write it and I got something like this:
## x= s \cos(\phi ), y= s \sin(\phi), z=z##
$$ \mathbf{A} = C \ln \left( \frac{x^2+y^2}{z^2} \right) = C \ln \left( \frac{ (s \cos(\phi )^2 + (s \sin(\phi )^2}{z^2} \right) = C \ln \frac{s^2}{z^2} $$
What is ##s##? Also, please fix the LaTeX.
On edit: Thank you for fixing it.
##s=\rho ##, I am sorry about the LaTeX, I am working on it.
Now I think I can manage to calculate the curl and the divergence. But I still don't understand why we used cylendrical coordinates?
Also this is in the ##\hat{z}##
Right. You should put in the ##\hat z## to avoid confusing anyone who might be reading this. Also, conventionally ##s## is ##r## but that's OK if you know what you're doing. Now find the curl and the divergence. Once you have these, I will explain to you why one should use cylindrical coordinates for this problem.
kuruman said:
Right. You should put in the ##\hat z## to avoid confusing anyone who might be reading this. Also, conventionally ##s## is##r## but that's OK if you know what you're doing. Now find the curl and the divergence. Once you have these, I will explain to you why one should use cylindrical coordinates.
Okay, so now that I have my ## A_z = C \ln \frac{s^2}{z^2} \hat{z} ## I can calculate the derivatives:
1) Curl:
$$ \nabla \times A = \frac{1}{s}\frac{\partial A_z}{\partial \phi} \hat{s} - \frac{\partial A_z}{\partial s} \hat{\phi} = 0 - \frac{2C}{s}\hat{\phi} = - \frac{2C}{s}\hat{\phi}.$$
2) Divergence:
$$ \nabla \cdot A = 0 + 0 + \frac{\partial A_z}{\partial z} = - \frac{2C}{z} $$
Very good. Compare these expressions and how easy it was to take derivatives with what you did earlier with Cartesian coordinates. Also, note that from three coordinate ##x##, ##y## and ##z## the problem has been reduced to two ##s## and ##z##.
Look at ##\vec\nabla \times \vec A.## It must be a magnetic field. Can you guess what can possibly generate a magnetic field that looks like this? If so, what is the appropriate value for ##C##?
Nothing is crossing my mind... I don't think I know what could generate this magnetic field. How should I think to get that?
Have you had a course in introductory physics where you calculated magnetic fields for various current configurations?
Yes, I have
So what I think you mean is that the constant ##C=\frac{\mu_0}{2\pi}##. But in that kind of experession we have a current in the dominator.
So we are talking about a magnetic field in a wire that is circular shaped?
There is never[/color] a current in the denominator of an expression for a magnetic field. The magnetic field is proportional to the current. That's Ampere's law. What current configuration are you thinking of? If you don't remember, look it up. There is no hurry.
kuruman said:
There is never a current in the denominator of an expression for a magnetic field. The magnetic field is proportional to the current. That's Ampere's law. What current configuration are you thinking of? If you don't remember, look it up. There is no hurry.
Sorry I meant numerator not denominator! I was thinking about an expression as the following
$$ \mathbf{B} = \frac{\mu_0 I}{2\pi s} \hat{\phi} $$
So I have an example in my book about "finding the magnetic field a distance s from a stright wire", the expression of its magnetic field reminded me of the one I got in the calculation for the curl.
That's the one. Nice work. Can you finish the problem now?
Now I am stuck when calculating the vector potential in coulomb gauge, A’. How can I find the A'?
It's not just any A'. It must have a curl that gives the B-field of a straight wire.
Yes, but how can I solve for it?
Does it mean that it is the same as the vector potential A?
No, it means that the curl of A' gives the same B-field. Furthermore, it must satisfy the Coulomb gauge ##\vec \nabla \cdot \vec A' =0##.
  • · Replies 19 ·
