Solving Work and Energy Problems on a Slope
10 replies · 3K views
NAkid
[SOLVED] work and energy problem
The first part asks
A car (m = 890.0 kg) traveling on a level road at 27.0 m/s (60.5 mph) can stop, locking its wheels, in a distance of 60.0 m (196.9 ft). Find the size of the horizontal force which the car applies on the road while stopping on the road. First solve this problem using work/energy concepts and then check your answer using kinematics/force law concepts.
I solved this by finding the acceleration and plugging into formula F=ma=5402N
The second part asks
Find the stopping distance of that same car when it is traveling up a 18.9deg slope, and it locks its wheels while traveling at 27.0 m/s (60.5 mph). Assume that muk does not depend on the speed.
3. The Attempt at a Solution [/b
I drew a free body diagram and came up with the following relationships
F-fk-mgsin(18.9)=ma where F=5402N
N-mgcos(18.9)=0
How do I solve for the horizontal distance? Is it just the vertical component of the Force?
That F=5402N doesn't belong here--that was the friction force from the first part.
Redo this without that extra force.
N-mgcos(18.9)=0
Good.
Solve for the acceleration. (Or the net force parallel to the road.)
OK, so i have F-ukmgcos(18.9)-mgsin(18.9)=ma. Can I solve for uk from the previous part of the problem and use it in this equation? If so, I still have one equation and 2 unknowns (F and a).
To solve for x i think I can use the equation Vf^2=V0^2+2ax, where Vf=0 and V0 is given.
What does the F stand for? You already have friction and weight accounted for.
Absolutely.
Lose the F!
F is the horizontal force (same as what the first part of problem asked for)
Well, I tried losing the F, which doesn't make much sense to me, and have -ukmgcos(18.9)-mgsin(18.9)=ma --> a=-14.57 m/s^2
use Vf^2=V0^2+2ax --> (27)^2=-2ax --> x=25.01m which STILL isn't right! :(
and i found uk with this equation from the first part
5402-ukmg=ma where a=-6.075
uk=1.23
In the first part, F is the net force on the car, which is just the friction. In the second part, you will use the [itex]\mu_k[/itex] from the first part, but not the F. You are already including friction as well as gravity.
What did you use for [itex]\mu_k[/itex]?
uk=1.23
Nope. Your value of force (5402N) is the friction!
and equation becomes -(.619)(890)(9.8)cos(18.9) - (890)(9.8)sin(18.9) = ma , solve for a, plug in (27)^2=-2ax
and x=40.89, great thank you!
