Solving ∫x²arctan(x)dx by parts
  • Topic:
  • Thread starter Thread starter Chipset3600
    Integral parts
5 replies · 2K views
Chipset3600
Hello MHB, I'm trying to solve this integral:[tex]\int x^2arctan(x)dx[/tex] by parts :
here is a litle bit of my resolution: http://i.imgur.com/dZk8M.jpg
when I tried to solve the integral I named B fell into a sort of lool lool.
All looks good so far. Let's focus on this guy, though:
\[\int\frac{x^3}{1+x^2}\,dx\]
I would first recommend you reduce the integrand using long division. Doing this correctly should yield
\[\frac{x^3}{1+x^2}=x-\frac{x}{1+x^2}\]
So, we see that
\[\int\frac{x^3}{1+x^2}\,dx=\int\left(x-\frac{x}{1+x^2}\right)\,dx\]
This should be a straightforward integration; no IBP is needed at this point.
Combine this result with everything else you have and you'll get your answer.
I hope this makes sense!
So, we see that
Thanks, it was much simpler, I tried to do polynomial division, but not crossed my mind to separate fractions by.
Thank you
I have tried another method: use the substitution $u = 1+x^2$. Therefore $du = 2x \, dx$ and $x^2 = u-1$. The integral changes shape into
$$\int \frac{x^3}{1+x^2} \, dx = \frac{1}{2} \int (u-1) \, du.$$
This yields
$$\frac{1}{2} \int (u-1) \, du = \frac{u^2}{4} + \frac{u}{2} + C = \frac{(x^2 +1)^2}{4} + \frac{(x^2 +1)}{2} + C.$$
However, it is a different answer. What is wrong?
This yields
Your integrand after making the substitution isn't correct. You should have
\[\int \frac{x^3}{1+x^2}\,dx\xrightarrow{u=x^2+1}{}\int \frac{u-1}{2u}\,du.\]
Good point, I had forgotten that part. Now the answer is complete (and easier). Thanks Chris! (Clapping)
