Solving z^5+16z'=0 in Complex Numbers
8 replies · 3K views
planauts
Solve z^5 + 16 conjugate(z) = 0 for z element of C.
z^5 + 16z' = 0
http://puu.sh/2EBqC.png
My first thought was to use z = a+bi and z' = a-bi
So:
(a+bi)5 + 16*(a-bi) = 0 + 0i And then expand and simplify to the real and non real parts. http://puu.sh/2EBwU.png
But it seems WAAY too complicated for a question worth only 4 marks.
I would appreciate if someone could post their thoughts.
Thanks!According to WolframAlpha: http://puu.sh/2EBKH.png
z^5 + 16z' = 0
So:
Thanks!
I think you'll have better luck with polar form than with rectangular. Try it.
I agree with these guys. Also, there are more solutions than wolfram alpha said. the button "more roots" gives the rest. (just in case you were confused that your roots were not the same as the ones you saw in wolfram alpha).
tiny-tim said:
hi planauts! :smile:
(try using the X2 button just above the Reply box :wink:)
try multipying by z :wink:
[itex]z^6 + 16|z|^2 = 0[/itex]
[itex](z^3+4|z|i)(z^3-4|z|i) = 0[/itex]
Factor further using sum and differences of cubes?
I'm not sure what you mean,
[itex]r^5e^{5i\theta}+16re^{-i\theta}=0[/itex]
[itex]r(r^4e^{5i\theta}+16e^{-i\theta})=0[/itex] r = 0
planauts said:
[itex] I'm not sure what you mean,<br /> <br /> [itex]r^5e^{5i\theta}+16re^{-i\theta}=0[/itex]<br /> [itex]r(r^4e^{5i\theta}+16e^{-i\theta})=0[/itex] r = 0[/itex]
[itex] <br /> That's exactly what I mean. Now multiply both sides by ##e^{i\theta}## and start thinking about what ##\theta## and r values might give you a solution.[/itex]
I end up with.
[itex]r^4e^{6i\theta} = -16[/itex]
I know theta = -pi/2 and r = 2 would give a solution...
How would I manipulate this equation so I can use the De Moivre theorem?
Should I let 4w = 6theta
So
[itex]r^4*e^{4wi} = -16[/itex]
Let [itex]p^4 = r*e^{wi} = -16[/itex]
And then solve for p and change the w angles to theta? I know that r has to be definitely 2 though.
Am I over complicating things again?
planauts said:
I end up with.
So
Maybe. Yes, r must be 2. So ##e^{6i\theta}=(-1)##. That means ##cos(6\theta)=(-1)## and ##sin(6\theta)=0##, right? That's deMoivre. I don't think it should be hard from there.
[itex](z^3+4|z|i)(z^3-4|z|i) = 0[/itex] …
no, it's easier now to put z = |z|e instead,
giving you |z|4e6iθ = -24
(same as you got anyway)
