What Are the Key Questions About Isometry in Manifolds?
Isometry in manifolds is defined by the condition that the metric remains unchanged under a transformation involving an infinitesimal parameter and a vector field satisfying the Killing equation. The infinitesimal parameter is constant to maintain global symmetry, while the vector field can depend on the coordinates. While isometries can be expressed in terms of local coordinates, they often require careful consideration of the manifold's topology, especially when multiple isometries are involved. The discussion highlights that continuous isometries can be coordinated under specific conditions, but this may not apply universally across all isometries. The concept of "gauged" isometries raises questions about the implications of allowing the infinitesimal parameter to vary with coordinates.
synoe
Isometry is the symmetry s.t.
<br /> g^\prime_{\mu\nu}(x)=g_{\mu\nu}(x)<br />
under the transformation x^\mu\to x^{\prime\mu}(x). This means under infinitesimal transformation
<br /> x^\mu\to x^\mu+\epsilon \xi^\mu(x)<br />
where \epsilon is any infinitesimal constant, the vector field \xi^\mu(x) satisfies Killing equation:
<br /> \nabla_\mu\xi_\nu(x)+\nabla_\nu\xi_\mu(x)=0.<br />
I have questions about above description.
1. Why the infinitesimal parameter \epsilon is constant and \xi^\mu is depend on x? The most general form seems to be \epsilon(x)\xi^\mu(x).
2.Is this transformation global or local? It's global symmetry because \epsilon is constant?
3.I have seen the description like "isometry means the metric is independent on the coordinate of the isometry direction." That is, if the isometry transformation is x^0\to x^0+\epsilon\xi(x), g_{\mu\nu}=g_{\mu\nu}(x^1,\dots) or \partial_0g_{\mu\nu}=0. But I think this is true only when the Killing equation have a constant solution. The statement is true in more general?
Not quite. If you have a diffeomorphism ##\phi : M \to M##, then ##\phi## is an isometry when
$$(\phi^* g'_{\mu\nu}) (\phi^{-1}(x')) = g_{\mu\nu}(x).$$
That is, you must pull back ##g'_{\mu\nu}## along ##\phi##.
##\xi^\mu(x)## is already an arbitrary function, so there is no need to make the infinitesimal parameter also a function.
Most mathematical texts are referring to global properties unless they say otherwise. That means if your manifold cannot be covered by a single chart, you need to concern yourself with transition functions to move between charts.
Often a Killing vector will vanish at some points on the manifold, so that although you do have an isometry, it does not necessarily "move" every point. For example, if you rotate a sphere, the north and south poles do not change.
That's a bit sloppy.
It is true that if you have a continuous isometry ##\xi^\mu##, it is possible to choose coordinates such that ##\xi = \partial_\varphi## for some coordinate ##\varphi##. However, if you have multiple isometries, it is not necessarily true that you can do this for all of them simultaneously. Again, the sphere is a good example. The sphere has three rotational isometries, but you can only "coordinatize" one of them at a time.
In general, you can choose adapted coordinates for any set of isometries that mutually commute (I believe this comes from the Frobenius theorem).
Thank you, BenNiehoff
Could you show the statement,
Ben Niehoff said:
It is true that if you have a continuous isometry ξμ\xi^\mu, it is possible to choose coordinates such that ξ=∂φ\xi = \partial_\varphi for some coordinate φ\varphi.
I interpreted this means the Killing equation have a constant solution like \xi^\mu=(1,0,0,\dots) if the manifold have a single continuous isometry. Is it true?
Can we consider "gauged" isometries? If we make naively \epsilon to be a function \epsilon(x), there is no change by absorbing x-dependence to \xi^\mu(x).
  • · Replies 16 ·
