Some questions while I self-learn Applied Calculus
49 replies · 10K views
user079622
In free time I start to solve differentials and integrals, I am doing fine, I just follow rules and solve the tasks.
I start solve some applied calculus tasks, but I dont really understand why for exmple second derivative represent acceleration, why first is speed, why I need to derivate Area=axb to find a and b with max area of recntangle if I know diagonal..etc
I know that differential is ratio of delta y / delta x. If I change x how much is change y, or simple tangent angle..
Can someone explain this?
What texts (physics and calculus) are you using?
Derivatives of displacement with respect to time, you mean. It's important to say what you are differentiating and with respect to what.
How fast you are going is a measure of the rate of change of your position. Rate of change of a function (position) as you vary something (time) is what derivatives measure. Acceleration is the rate of change of velocity with respect to time - so ditto.
Imagine doing it the hard way - draw all the possible rectangles, measure the area as you vary ##a##. You could draw a graph of area as a function of one side length. Note that the maximum area is the top of the curve you draw on the graph. So the slope is changing from positive to negative at that point - it's zero. So to find the maximum area you take the derivative of that graph and set it to zero.
Reply
I learn and solve tasks from youtube videos, I also bought book mathematics for engineering university, but I didnt learn from this book yet.
Do you think is better to learn from book or what is best source to learn?
I rember from my university time(long time ago) integral is area under curve, so wondered why I derivate function A=axb for this...
I am struggle to connect what has rate of something change(differential) with area, speed..
Derivatives are rates of change of some quantity with respect to another. Velocity is the rate of change of position with respect to time (also described as the time rate of change of position). If s(t) represents the position at time t, the velocity v(t) is the time rate of change of position. (Note that physics books often use s to represent position -- I don't know why.) So ##v(t) = \frac d {dt}(s(t))## also written as s'(t).
Acceleration is the time rate of change of velocity, so ##a(t) = \frac{d^2}{dt^2}(s(t)) = \frac d{dt} v(t)##, also written as s''(t) or v'(t).
No, what you're talking about is the derivative, which is different from the differential of something. Also, the derivative is a limit.
If y = f(x), the derivative is ##\frac{dy}{dx} = \lim_{h \to 0}\frac{f(x +h) - f(x)}h##.
The differential of y is defined as ##dy = f'(x) dx##.
Not the best source.
From a reputable textbook.
You don't "derivate" a function -- you differentiate it. Doesn't make sense, but it is what it is.
I don't understand what you mean when you say you "derivate function A = axb for this." Another member has already mentioned what happens when you integrate a function. The most basic example of integration is to find the area under a curve.
Reply
I think OP is referring to maximizing Area - as for a rectangle when given some constraint such as perimeter.
I can say with a high degree of confidence that you will make more progress with a good textbook than a bunch of YouTube videos.
Reply
user079622 said:
... I rember from my university time(long time ago) integral is area under curve, so wondered why I derivate function A=axb for this...
The relationship between derivatives and integrals (that the integral is the anti derivative) is "the fundamental theorem of calculus." Look it up.
I dont know what is difference of differential vs derivation , I mean on sign ´
English is not my first language
Diagonal is 4cm, I must find sides a and b for rectangular with max area.
A=a x b --> MAX
d^2=a^2 x b^2
But problem in book there is no professor who explain, you must grasp everything alone.
Khan academy?
https://www.khanacademy.org
And when you ask questions of a recorded video, does it answer you back? And for how long has this been happening?
No. How long I study calculus? Few days
I explained the difference between a derivative and a differential in post #5.
A=a x b --> MAX
d^2=a^2 x b^2
One of the most common applications of differentiation is to find the maximum value of some function. To lessen the chance of confusion I'm going to call the sides l and w (for length and width). For this problem, since the diagonal is 4 cm, then ##w^2 + l^2 = 16##, so ##l^2 = 16 - w^2 \Rightarrow l = \pm \sqrt{16 - w^2}##
We can assume that neither side is negative, so ##l = \sqrt{16 - w^2}##
Then we can write the area of the rectangle as a function of side w as ##A(w) = w \cdot \sqrt{16 - w^2}##.
A maximum value occurs at a point (w, A(w)) at which
  • A'(w) = 0 or
  • w is an endpoint of some restricted domain or
  • a point at which A(w) is undefined.
Khan academy?
Khan Academy is better than most, but IMO, not as good as a textbook. As pointed out already, after you have watched a video, if you have a question, you can't ask the video for an answer to your question.
  • A'(w) = 0 or
Why you use A(w) and A(ω) ? Is this tipfeler?
Yes but you cant ask question to a book as well, plus book has lots of proofs that is not maybe necessary.
I used A(w), where w represents the width of the rectangle, because I didn't want to have both A and a in the same equation. I didn't use A(ω) (ω is lower-case Greek ##\Omega##). Maybe you thought that the w in the LaTeX expression looked like ##\omega##.
No, it wasn't tipfeler (or in English, typo).
Most of the calculus textbooks I've seen (lots) have very few proofs.
  • A'(w) = 0 or
So, @user079622 , can you differentiate the expression ##A(w) = w \cdot \sqrt{16 - w^2}##
to get ##\frac {d} {dw} (w \cdot \sqrt{16 - w^2}) ##
You will need to use the product rule (https://en.wikipedia.org/wiki/Product_rule)
Do you think that book is even better option from watching class video lecture, what site/channel do you suggest?
For example like this
Yes I can do it.
Official lecture series from a reputable university are a good option. Especially if they follow a textbook that you have.
There are also some good unofficial sources, like this guy:
https://thebrightsideofmathematics.com/
The main problem is that these series rarely give the viewer access to problem sheets. I quite like pausing the video and trying to figure out the next bit myself. If you can do that, then you definitely understand the material.
Something like this?
You'll have to figure out and tweak over time the learning method(s) that work best for you.
Hill said:
It's a language. Don't synonyms make a language richer?
Why call it df/dx if I can write simple and less confusing f´(x) ?
Many reasons. For example, sometimes you need to make a manipulation such as to go from ##\frac {df} {dx} = g(x)## to ## df = g(x) dx##.
What this letters "d" mean?
The notation ##\frac{dy}{dx}## is so common that there is nothing to be gained by complaining about it.
Infinitesimal change.
Here is some different letters
8242cb974856d243f0e51e3fe1e018ffeadbeb75
I will stop watching youtube and try learn from book.
When I learn from university book, does it make sense to write notes in my notebook something that is already written in book or this is just waste of time?
What learning strategy do you suggest?
(for sure I will solve tasks in notebook..)
This is rather enlightening to those offering advice to you.
What is your mathematical background?
What math have you studied previously?
What mathematical skills do you have?
Sorry, but this , learning style and methods, is something you need to develop by/for yourself and tweak it as you go.
