Sommerfeld quantisation:relation between energy and potential
  • Level: Graduate
  • Thread starter krishna mohan
    Energy Potential
2 replies · 3K views · last reply
krishna mohan
I found the following question in a question paper.
If the potential experienced by a particle in one dimension is given by [tex]ax^4[/tex], how does the energy of the particle depend on the parameter a? Use Bohr-Sommerfeld quantisation formula.. I know how to find the dependence of energy on n, the integer that occurs in the quantisation.
But how does it depend on a?
Since
Hamiltonian is [tex]\ K+V[/tex] ,
Energy is [tex]\ K+ax^4[/tex].
I don't know what else I can say.
For example, in the harmonic oscillator, the potential V is,
[tex]V = ax^2 = \frac{1}{2}m \omega^{2}x^2[/tex]
So, the total energy is,
[tex]E= K+V = \frac{p_{x}^2}{2m}+\frac{1}{2}m \omega^{2}x^2(=ax^2)[/tex]
As shown in this thread, The Bohr-Sommerfeld quantization formula is, (in a quarter period)
[tex]\oint p_{x}dx = nh \to \sqrt{2m}\int_{0}^{\sqrt{\frac{E}{a}}}\sqrt{E-ax^2}dx = \frac{1}{4}nh[/tex]
change the variable to [tex]\theta[/tex] as follows,
[tex]\sqrt{\frac{a}{E}}x=sin\theta, \quad E\sqrt{\frac{2m}{a}}\int_{0}^{\frac{\pi}{2}}cos^2\theta d\theta =\frac{\sqrt{2m}E\pi}{4\sqrt{a}}=\frac{1}{4}nh[/tex]
So if we erase the a, the the total energy E is,
[tex]E=\frac{nh\sqrt{a}}{\sqrt{2m}\pi}=\frac{nh\omega}{2\pi}=n\hbar\omega[/tex]
This result shows the interval of the energy E is [tex]\hbar\omega[/tex]
But as shown in the ground state electron of the Bohr hydrogen model, the electron has the orbital angular momentum 1 (x [tex]\hbar[/tex]) instead of the spin 1/2. So we have to consider the minimum rotation (not 1-D) in the Bohr model.
This magnetic moment which can be measured by the experiment is the same as the QM hydrogen model because the magnetic moments(angular momentum x g-factor) are 1 x 1 (in the Bor model) = 1/2 x 2 (in the QM model).
If the angular momentum is [tex]\hbar[/tex], the electron naturally return by one rotation as follows, (also in the result of this experiment)
[tex]L_{z}(=-i\hbar\frac{d}{d\varphi})\phi_{m}(\varphi) = m\hbar\phi_{m}(\varphi), \to \quad \phi_{m}(\varphi)=e^{im\varphi}[/tex]
Sorry, the case of [tex]V=ax^4[/tex] is a little complicated, so I'm glad if you calculate like this, and tell me the result.
My question was not about the dependence on the quantum number n obtained from the quantisation condition...
It was about the dependence of the energy on the parameter a in the Hamiltonian..that is the potential energy being given as [tex]a x^4[/tex]...
As for dependence on n, it can be easily accomplished..see this video...at around the thirty minute mark...
