Sound waves problem help
15 replies · 4K views · last reply
FlipStyle1308
I am clueless on how to approach the following problem, and was wondering if anyone would be able to help me. Thanks!
Sound waves X and Y have wavelengths of 1 m and 2 m, and amplitudes of 0.01 Pa, respectively. The frequency of X is 343 Hz, and the frequency of Y is 171.5 Hz. The intensity of Y is greater than that of X by ___ times. Soundwave Y is ___ dB louder than soundwave X.
For the 1st part of the question, it may be helpful to note that [tex]Intensity\propto (Amplitude)^2[/tex]
Just to double check, does that symbol mean indirectly proportional?
No, it mean directly proportional to. If you wish to form an equality you must add in a constant [itex]I = kAmp^2[/itex]
~H
So would this be the answer...
The intensity of Y is greater than that of X by 10,000 times. Soundwave Y is 100 dB louder than soundwave X. ?
I don't see how you got 10000.
sound waves are abit tricky because there are two ways to represent them: in terms of a *displacement wave* or in terms of a *pressure wave*.
If I recall correctly (don't take my word for it!), the formula are
[itex]I= {1 \over 2} \rho v \omega^2 s_{max}^2[/itex] in terms of the displacement amplitude or [itex]I = {1\over 2} {\Delta P_{max}^2 \over \rho v}[/itex] ( I am quoting from memory, I don't have my books here so caveat emptor). You must have seen these equations?
So I am a bit confused. If the two waves have the same *pressure* amplitude, they would have the same intensity (after checking that they travel at the same speed and they do..as they must :smile: ).
If you were given the *displacement* amplitude to be the same, I could see how the different frequencies would influence the result.
So I am :rolleyes: confused.
I used the equation that Hootenanny gave and plugged in the amplitudes of 0.01Pa and 1 Pa, getting inertias of 0.0001 and 1, respectively. 1 is 10,000 times bigger than 0.0001, and that is how I got my answer.
Okay, I am confused with all these equations. Are you guys able to provide me a step-by-step process for solving this equation?
I think there is some confusion among the posters because there may be something you left out in your first post. In it, you wrote "Sound waves X and Y have wavelengths of 1 m and 2 m, and amplitudes of 0.01 Pa, respectively". Does the value of 0.01 refer to X, Y, or both? If I am not mistaken, X has an amplitude of 0.01 Pa and Y's is 1 Pa, as you mentioned in one of your later posts that "I used the equation that Hootenanny gave and plugged in the amplitudes of 0.01Pa and 1 Pa".
Perhaps you would like to clarify?
Sound waves X and Y have wavelengths of 1 m and 2 m, and amplitudes of 0.01 Pa and 1 Pa, respectively. The frequency of X is 343 Hz, and the frequency of Y is 171.5 Hz. The intensity of Y is greater than that of X by ___ times. Soundwave Y is ___ dB louder than soundwave X.
Fixed. I didn't notice that! Sorry! Is my answer still correct?
Does intensity vary with wavelength and frequency? If no, then I think your answer of 10,000 for the 1st part of the question should be correct.
For the 2nd part, use the equation that Hootenanny gave in post 8 (note that the logarithm has base 10). You may not know the absolute values of the intensities, but this should not be a problem. Just let the intensity of X be a and the intensity of Y be 10,000a and you can go from there. Also, remember that [tex]I_{0}[/tex] in the equation given is a constant.
So I solve for:
10log(10,000)? How do I plug these intensities in?
I don't really get what you mean by "plugging the intensities in". Perhaps you would like to show some working?
I got it correct, thanks for the help!
Good! But take note of the fact that [tex]I_{0}[/tex] is a constant value (the threshold of hearing, if I understand it correctly). The [tex]log_{10}(I_{0})[/tex] term should cancel off when you are doing your working.
