What Causes the Heat in Your Vehicle's CD Player?
  • Context: High School
  • Thread starter Thread starter houlahound
    Heat Source
The discussion revolves around the sources of heat generated in a vehicle's CD player during operation. Participants explore various components that may contribute to this heat, including the laser, electronics, and amplifier, while considering different audio formats and their effects on heat generation.
  • One participant notes that the CD feels warm after playing for a while and questions the source of the heat, initially considering the LED but dismissing it.
  • Another participant suggests that the heat could be a combination of the laser/LED and the electronics, mentioning the laser's power of about 5 mW.
  • A different participant expresses surprise at the 5 mW power level, questioning its necessity for reading CDs and comparing it to the heat generated when playing other formats like MP3.
  • Some participants speculate that the CD player may not keep the laser continuously on when reading compressed data, unlike uncompressed audio, which could affect heat generation.
  • There is a discussion about the wavelength of light used in Blu-ray technology and its potential impact on heat generation, with one participant noting that blue light is often considered "cool" but questioning its relation to heating.
  • Another participant elaborates on the relationship between light color and heating, explaining that incubators and fires emit infrared radiation, which is primarily responsible for heating.
  • One participant estimates that in-car audio systems, which include CD players and amplifiers, could dissipate several watts of heat, especially at higher volume levels.
  • Another participant asserts that the amplifier is likely the primary source of heat, as it consumes significantly more power than the laser.
  • Further elaboration on power consumption suggests that a typical car audio system could draw substantial current, leading to considerable heat generation within the stereo unit.
  • A participant reflects on their experience with a handheld CD player, noting it did not generate noticeable heat, implying lower power usage compared to car systems.
  • One participant expresses appreciation for the discussion, indicating interest in the topic.
Participants present multiple competing views regarding the sources of heat in the CD player, with no consensus reached on the primary contributor. The discussion remains unresolved as participants explore various hypotheses and considerations.
Some assumptions about power consumption and heat generation are not fully quantified, and the discussion includes varying perspectives on the relationship between light wavelength and heating effects.
houlahound
While changing a CD in my vehicle CD player I noticed the CD is quiet a few degrees above ambient after it has been playing for awhile, not measured just felt very warm to touch.
the question is what is the source of the heat?
I considered the LED but that makes no sense.
Is it the motor that rotates the CD, seems unlikely due to the air gap between the CD surface and the rest of the system?
Science news on Phys.org
I would assume it is a combination of the laser/LED and the heat of the electronics. I think the laser is only about 5 mW in power, but I don't know how much power the rest of the electronics uses.
5mW seems like a lot of power?
I was unaware they were that strong or needed to be, why would that much power be required to read off a CD at such short range.the system playing radio or other formats eg mp3 does not generate the same heat as when playing the CD.
interested if Blu-ray generates more or less surface on the disc heat being a colder frequency than red on the CD.
MP3 files are compressed and take up MUCH less room than regular CD audio. It's possible that the disk drive doesn't leave the laser continually turned on to read the compressed data as it does with uncompressed audio. That's just a guess though.
A Blu-Ray DVD requires light around 400 nm in wavelength, which is on the blue/purple end of the spectrum. I know blue and purple are considered to be "cool" and red to be "warm" by many, but those concepts have nothing to do with heat.
"A Blu-Ray DVD requires light around 400 nm in wavelength, which is on the blue/purple end of the spectrum. I know blue and purple are considered to be "cool" and red to be "warm" by many, but those concepts have nothing to do with heat."but why not, they have everything to do with "heating" as per eg; incubators are red not blue, warmth from fire...etc, etc, etc.
Incubators and fires emit light primarily in the IR range, which is where most of their heating comes from. This is because a hot object emits EM radiation along a spectrum, whose emitted power vs wavelength depends almost entirely on the temperature of the object. Very cold objects emit barely any radiation and the majority of it is at very long wavelengths. For example, the CMB spectrum is essentially identical to that emitted by an object just under 3 kelvin and sits primarily within the microwave band. You and I are much warmer and the radiation emitted by our bodies falls primarily in the long-wavelength part of the infrared band. Incandescent light bulbs are around 2,000 - 3,300 kelvin and while they emit lots of visible light, the majority of the radiation falls within the near-IR band.
Fire and incubator lights are cooler than a standard tungsten incandescent light bulb used for household lighting and thus they emit barely any visible light in the blue or green areas of the visible band, making them look red, orange, or yellow.
See this article: https://en.wikipedia.org/wiki/Black-body_radiation
Most in car systems have a CD player, radio and audio amplifier all in one unit. At sensible volume levels I think they draw a bit under 1A @ 12V. So potentially you might have several watts of heat being dissipated in a box that's not exactly well cooled.
It is almost certainly the amplifier for the CD player. That has between a thousand and 100,000x more power than the laser.
and that would be on the extremely low side
consider a system with 4 speakers ( not uncommon in cars) and even a decent system at low power putting out say 30W per channel
there 120W of music power, power drawn from the 12V system will be around double that.
Lets err on the conservative side and say 200W from the 12V supply = 16.6 Amps
the power dissipation within the stereo unit is going to cause LOTS of equip heating
any heating effects of a 5mW laser wouldn't even be noticeable
Dave
Makes sense. My old handheld CD player never noticeably heated up the CD. I'm sure it only used a few watts since it didn't have to drive speakers larger than headphones.
thanks for replies and thoughts. just seemed like an interesting question to me.
  • · Replies 27 ·
  • · Replies 21 ·
  • · Replies 19 ·
12K
