Space-Time — Momentum-Energy uncertainty relations
The discussion revolves around the concepts of uncertainty relations in quantum mechanics, particularly focusing on the potential existence of additional uncertainty pairs involving time, space, momentum, and energy. Participants explore the implications of these uncertainties in various contexts, including the double-slit experiment and the treatment of time in quantum mechanics.
  • Some participants reference the idea of complementarity, suggesting that classical concepts cannot be simultaneously applied in quantum mechanics, leading to uncertainty in measurements of position and momentum.
  • There is a proposal for the existence of additional uncertainty relations, such as time-location or time-energy uncertainties, alongside the well-known position-momentum and energy-time uncertainties.
  • One participant notes the complexity of quantum mechanics due to different levels of formalism, from basic quantum mechanics to quantum gravity, and the varying treatment of time across these frameworks.
  • Concerns are raised about whether time-location-momentum-energy uncertainties are inherent in all quantum experiments, particularly in relation to the double-slit experiment.
  • Another participant highlights that while energy-time relations exist, they are not analogous to position-momentum relations and that general time-indeterminacy remains a topic of discussion.
  • A hypothetical scenario is presented regarding the momentum of an electron passing through slits, questioning how changes in momentum affect energy conservation and the coherence of the slits as sources of interference.
Participants express a range of views on the nature of uncertainty in quantum mechanics, with no clear consensus on the existence of additional uncertainty relations or the implications of time treatment in quantum frameworks. The discussion remains unresolved with multiple competing perspectives.
Participants acknowledge the limitations of their understanding and the complexity of the subject matter, particularly regarding the treatment of time and the implications of uncertainty in various quantum mechanical contexts.
etamorphmagus
From the wikipedia page on http://en.wikipedia.org/wiki/Complementarity_(physics)" :
In a restricted sense, complementarity is the idea that classical concepts such as space-time location and energy-momentum, which in classical physics were always combined into a single picture, cannot be so combined in quantum mechanics. In any given situation, the use of certain classical concepts excludes the simultaneous meaningful application of other classical concepts. For example, if an apparatus of screens and shutters is used to localize a particle in space-time, momentum-energy concepts become inapplicable. This is reflected in the formalism in the fact that a localized wave-packet is a superposition of plane waves, and therefore does not have a definite energy-momentum. This reciprocal limitation in the possibilities of definition of complementary concepts corresponds exactly to the limitations of the classical picture, where any attempt at the localization of a particle through objects such as slits in diaphragms introduces the possibility of an exchange of momentum with those objects, which is in principle uncontrollable if those objects are to serve their intended purpose of defining a space-time frame. Another famous example is 'Heisenberg's microscope', using which Heisenberg first discovered his uncertainty relations.
As I recently noticed in the double-slit experiment there is a lot of time-uncertainty, not only position-momentum uncertainty. That is shown in the fact that the probability wave does not reach the screen gradually, but instantly, for distribution purposes, to create interference with single-particles at a time, rather than a beam. So from this article I wonder, is there a relation on space-time uncertainty? Is there a relation of time-energy relation (in the double slit?)? And time-momentum etc? Instead of a pair of variables, quad-uncertainty??
I know this is always true: [tex]\Delta x \Delta p\approx h[/tex]
And this is true for particle decays: [tex]\Delta E \Delta t\approx h[/tex]
Is there something like this [tex]\Delta t \Delta x\approx h[/tex] or [tex]\Delta E \Delta t\approx h[/tex] or even this [tex]\Delta E \Delta t \Delta x \Delta p\approx h[/tex] ?!
Seems to be that there are 4 uncertainty pairs, anyhow:
[PLAIN]http://img228.imageshack.us/img228/4797/89768410.gif
Please, this is a really frustrating technical part of QM I face. From a different thread I understood that time-uncertainty is implied in the double-slit experiment as well as other uncertainties - so this is a decent question.
I'll appreciate any attempt to reply. Thank you.
Yes it is a decent question. I've read through the suggested previous threads on the same topic and there are lots of good answers, but unfortunately no one knock-down answer. So we must end up staying a bit confused.
The reason is that there are several levels of quantum formalism and we require a deeper answer at each stage as we go from
quantum mechanics -> relativistic quantum mechanics -> relativistic quantum field theory -> quantum gravity.
My only advice would be that when reading answers, ask which formalism is being assumed. Also beware that when you get to the final level (quantum gravity) there is no one answer because there is no completed quantum gravity theory.
Also beware that even within the basic quantum mechanics formalism there are several equivalent pictures of the same thing (e.g. Schrödinger picture, Heisenberg picture, operator approach, path integral approach) and time is treated a bit differently in each.
I understand, the different approaches and levels make it very complicated.
Is it safe to say though that time-location-momentum-energy uncertainties are inherent in QM and always there in every experiment? Which will manifest in not knowing the time-travel of a particle in the double-slit experiment, and not being able to produce EM-radiation of one wavelength ideally, because energy-momentum uncertainty is always there - coupled with location uncertainty and probably time too.
In the different approaches they treat time differently, is it because time is not used classically, and use a unified space-time (makes sense) - which is not intuitive for us anyways so it doesn't matter, the methods are all mathematical?
I guess it is safe to say all that.
Yes: the basic conflict of how to treat time, is that relativity demands we treat position and time on an equal footing as 4-vectors, however the canonical formulation of quantum mechanics requires we treat time separately. That's roughly it.
Have a look at Ballentine section 12.3 for a readable discussion on
energy-time indeterminacy relations from a modern perspective.
Here's a quote from his concluding paragraph at the end of that section:
[...] There is no energy-time relation that is closely analogous to the
well-known position-momentum indeterminacy relation. However, there
are several useful inequalities relating some measure of the width of the
energy distribution to some aspect of the time dependence. But none
of these inequalities has such a priority as to be called the
energy-time indeterminacy relation.
I know, the energy-time relation for particle decays - it explains the short life-span of heavy particles.
But I talk about general time-indeterminacy, like in the double slit experiment where you can't know how long it takes for the particle to travel from gun to screen, or the time it take the probability wave to advance. Taking all the particles into account that create interference patten the only explanation is that averagely the wave-fronts reach the screen at the same time, or maybe different points reach first, randomly - Point is, the wave is not advancing in a circle-fashion with time, if it would, you couldn't really explain the interference distribution of the screen. I would draw it for you if you like, it is hard to explain with words.
Just thought about something more.
Say an electron moves towards the slits with 100% momentum in the x direction, meaning 0 uncertainty on y-momentum. After it passes the slits the y-location is localized so there is uncertainty in y-momentum, which gives is a total momentum which is a combination of x- and y-momentum. It means it has higher momentum than before the slits = higher energy.
If this is so, how can the 2 slits be coherent sources? If the wavelength is different for different directions, it wouldn't create an interference pattern. Maybe this wouldn't matter if the y-momentum is very small, but I don't think this is the case. What happens to energy conservation here? Is the answer is that y-momentum increases and x-momentum decreases so direction is different but total energy is the same? But then what decreases x-momentum? It's not the uncertainty principle - the x-location is completely unknown.
I think the real answer to this conundrum is coupling time and energy uncertainties somewhere to the location-momentum uncertainties. So what do you think about the problem with the change in overall momentum in the slits?
Hi.
#1
I would like to comment on your interesting topics of slit. In optics or electron beam diffraction at slits or crystals does not change frequency or wavelength of light i.e. energy.
#2
In standard QM, space(location x,y,z), momenta in x,y,z direction and energy are all operators but time is not an operator but a parameter. Uncertainty relation between time and energy should be interpreted not the same way as that of coordinate and momentum. Some scientists do not like it and have been trying to constract time operator but I have not heard their general success.
Regards.
sweet springs said:
Hi.
I would like to comment on your interesting topics of slit. In optics diffraction at slits does not change frequency or wavelength of light i.e. energy.
Regards.
Ok, but optics is a classical approximation, how does it sit with the uncertainty principle?
I think I have an explanation:
The wave-function interacts with the slit, it places some boundaries on the probability-wave, so it might be that y-momentum increases but x-momentum decreases so that only the direction changes, not the magnitude. This way energy conservation remains, and momentum conservation too, by the wall itself moving in the opposite direction (the wall with the slits).
I still wonder at the mechanism of the momentum-change. Should we even treat it this way? The uncertainty principle is a classical treatment of particles in the slits, when in fact the correct treatment is of a wave, a wave does interact with the wall.
Also, when talking about different uncertainties in this experiment, there is no energy uncertainty after all - we get the same "packet" every time.
Yeah, this strengthens the fact that QM is very incomplete, but BruceG said that there is a relativistic QM, surely, this treats time differently?
I'm pretty sure you'll find that energy is conserved. :-)
To analyze this stuff properly, one must think of an initial state (corresponding to
a plane wave), and the screen with 2 slits as an operator acting upon the initial
state to produce a new state. Then compute matrix elements between the new state
and position eigenstates corresponding to an array of detectors.
I.e., trying to mix classical reasoning and QM is a minefield. Better to stick
with hard core QM and work things out properly - computing both the
expectations and variances.
It wasn't clear from your reply whether you've studied Ballentine in detail,
but if you haven't then it would almost certainly be a profitable investment.
So basically the notion of explaining diffraction with the uncertainty principle is an approximation of physics-classes, to show that narrowing the slit increases diffraction efficiency, but really you can't understand it like that. I'm talking about Lewin's lectures from MIT.
And I'll take Ballentine in mind, however I'm only starting bachelor's.
The lecture I talked about:
Heisenberg's Uncertainty Principle by Walter Lewin
link: http://www.youtube.com/watch?v=IcOJHJJpd0w&feature=player_embedded
time: about 33:00
He speaks about uncertainty in location and momentum- BUT NOT AROUND A SPECIFIED AXIS. Is it wrong to say that? because then you could say that certainty in y-location results in uncertainty in x- and y- momentum, so that the direction changes, not the magnitude of the momentum.
time: about 33:00
Unfortunately, I'm stuck at the end of a slow link which makes it impractical
for me to download video.
Consider the operators [itex]x, p_x, y, p_y[/itex]. There's a nontrivial uncertainty
relation between [itex]x, p_x[/itex] because they don't commute. There's also a similar
nontrivial uncertainty relation between [itex]y, p_y[/itex].
In contrast, [itex]x[/itex] and [itex]p_y[/itex] do commute, hence you don't get
a nontrivial uncertainty relation between these two.
O.K. but then there's a problem:
[itex]p_{i}[/itex] initial momentum magnitude
[itex]p_{f}[/itex] final momentum magnitude
Initial state: [itex]p_x, p_y=0[/itex] , so [itex]p_{i} = p_x[/itex]
At slit: [itex]p_x, p_y[/itex], and [itex]p_{f}[/itex] is a composition of [itex]p_x, p_y[/itex]
So, [itex]p_{f} > p_{i}[/itex]
Explanation?
The last statement doesn't follow. Momentum is a vector, but you said
[itex]p_f, p_i[/itex] were "magnitudes".
Like I said before, one must track through the QM math carefully.
If you haven't got that far yet, I guess maybe you'll have to be patient
until you're a bit further into your degree. I doubt I can help much
more on this until then. Cheers.
I meant that [tex]P_{i}=P_{x}[/tex] and [tex]P_{f}=\sqrt{P^{2}_{x}+P^{2}_{y}}[/tex] so [tex]P_{f}>P_{i}[/tex]. I was talking about magnitudes after all the vector operations. Momentum not conserved? How QM deals with simple diffraction, I mean — professors of physics demonstrate the HUP with laser diffraction. So what is the problem, even generally speaking, please?
Sorry for bringing this up again, but maybe someone has some response regarding the last message?
  • · Replies 32 ·
  • · Replies 27 ·
  • · Replies 20 ·
  • · Replies 33 ·
