Spacetime Curve: Mass Effects & 5th Dimension
  • Context: High School
  • Thread starter Thread starter diazdaiz
    Curves Spacetime
The discussion clarifies that mass does not curve spacetime into a new fifth dimension, as there are two types of curvature: intrinsic and extrinsic. Intrinsic curvature, relevant to relativity, can be measured independently of external spaces, while extrinsic curvature requires embedding in higher dimensions. The universe is not considered to be embedded in a higher-dimensional space, making extrinsic curvature irrelevant in the context of relativity. Therefore, only four dimensions—three spatial and one temporal—are necessary to describe the curvature used in relativity.
  • Understanding of intrinsic and extrinsic curvature
  • Familiarity with general relativity concepts
  • Basic knowledge of geometric principles
  • Awareness of dimensionality in physics
  • Research intrinsic curvature in general relativity
  • Explore the implications of extrinsic curvature in higher-dimensional theories
  • Study the geometry of manifolds and their applications
  • Investigate the mathematical foundations of spacetime metrics
Students of physics, particularly those studying general relativity, mathematicians interested in geometry, and anyone seeking to understand the implications of curvature in spacetime.
diazdaiz
i am new at relativity, it said mass can curve spacetime, does this mean spacetime will curve to a new 5th dimension (1-3 for space dimension, 4 for time dimension)?
No, it doesn't mean that.
There are two types of curvature, intrinsic and extrinsic curvature.
Intrinsic curvature can be measured without reference to an external space - for example, the intrinsic curvature of the surface of the Earth can be detected by drawing a large triangle and noting that the angles don't sum to 180°.
On the other hand, extrinsic curvature requires a space to be embedded in a higher-dimensional space. For example if you take the surface of a cylinder, this is curved in the sense that straight lines in 3d space that touch the surface of the cylinder don't necessarily stay touching the cylinder.
A surface can have extrinsic curvature but not intrinsic curvature (for example, the surface of the cylinder has no intrinsic curvature - triangles drawn on it have angles that sum to 180°). I suppose it might have intrinsic curvature but not extrinsic (can't think of an example, though). Or it might have both.
In relativity, we only care about intrinsic curvature. As far as we know, the universe is not embedded in a higher dimensional space, so it doesn't make sense to talk about extrinsic curvature. So, as martinbn says, the answer to your question is no. We have no need to propose more than four dimensions to talk about the kind of curvature that is used in relativity.
Bit of a contrived example, but consider the surface of a hemisphere. Project this surface vertically onto its equatorial plane. Inherit the distance metric from the original hemisphere to judge "straight lines" in the resulting space. It now has intrinsic but not extrinsic curvature.
Or the other way around, I guess. Embed the manifold in a higher dimensional manifold whose metric is contrived to match that of the embedded manifold where appropriate.
  • · Replies 19 ·
  • · Replies 29 ·
  • · Replies 58 ·
  • · Replies 23 ·
