Sparse Matrix using linked list of a linked list
  • Thread starter Thread starter zorro
    List Matrix
12 replies · 10K views
zorro
The idea is to create following type of structure:
first_row_with_a_nonzero_cell->next_row_with_a_nonzerocell->...->NULL
rowN_with_a_nonzerocell->firstnonzerocolinrowN->nextnonzerocolinrowN...->NULL
Input file is a 20x50 sparse matrix.
The only problem I have is while switching to next row, when a '\0' is encountered.
The new rownode I create using link2 function, should point to the header of the cell node of same row. But I created head1 as a pointer to the first non zero element of the first row. And I can't use the same head1 to point to the first non zero element of the second row.
How do I make sure that everytime a new row is created, the rownode of that row points to the first non zero cell of the same row?
Code:
#include <stdio.h>
struct cellnode {
	int val;
	int col;
	struct cellnode *nextcell;
struct rownode {
	int row;
	struct rownode *firstcell;
	struct rownode *nextrow;
struct rownode * create_rownode(){
	struct rownode *new;
	new = (struct rownode *)malloc(sizeof(struct cellnode));
	return new;
	};struct rownode *head2=NULL;
struct cellnode * create_cellnode(){
	struct cellnode *new;
	new = (struct cellnode *)malloc(sizeof(struct cellnode));
	return new;
	};struct cellnode *head1=NULL;
void link1(int v,int c){
	struct cellnode *temp,*new;
	new=create_cellnode();
	new->val=v;
	new->col=c;
	if(head1==NULL)
		head1=new;
	else{
		temp=head1;
		while(temp->nextcell!=NULL){
			temp=temp->nextcell;
		temp->nextcell=new;
	if(c=19)
	new->nextcell=NULL;
void link2(int r){
	struct rownode *temp,*new;
	new=create_rownode();
	new->row=r;
	new->firstcell=head1;
	new->nextrow=NULL;
	if(head2==NULL)
		head2=new;
	else{
		temp=head2;
		while(temp->nextrow!=NULL){
			temp=temp->nextrow;
		temp->nextrow=new;
main() {
	FILE *fp;
	char i,c;
	int n,col=0,row=0;
	fp=fopen("1.txt","r");
	if(fp==NULL){
		printf("cannot open");
		return;
	else printf("File Opened\n");
	while(((i=getc(fp))!=EOF)){
	printf("%c",i);
	rewind(fp);
		while(i!='\0'){
		fscanf(fp,"%d%c",&n,&c);
			if(n!=0){
				link1(n,col);
			i=getc(fp);
			col++;
		if(i='\0'){
			link2(row);
			head1=NULL;
			col=0;
			row++;
on Phys.org
Abdul Quadeer said:
Code:
	new = (struct rownode *)malloc(sizeof(struct [B]cellnode[/B]));
This should be:
Code:
	new = (struct rownode *)malloc(sizeof(struct rownode));
If you need a head pointer for each row, couldn't you add a head pointer to the rownode structure?
Isn't the firstcell of row node structure itself a head pointer to the first non-zero valued node of cell node?
I hope you understood my problem.
In the following code snippet:
Code:
void link2(int r){
	new->row=r;
	new->nextrow=NULL;...
the firstcell of the newly created node should point to the first non zero valued node of the cellnode. In other words, it should point to the head pointer of the cellnode structure of that row.
My code will work for the first row. But when it goes to second, head1 has the address of the first non zero element of the second row but then the previous rownode will lose the address of the first non zero element of the first row.
I also need to print the values of the linked list at the end.
Abdul, there are quite a few problems in your code.
rcglr was correct about new = (struct rownode *)malloc(sizeof(struct cellnode));. You will get lucky on a 32 bit machine because both rownode and cellnode are the same size, 12 bytes, on such a machine. You will get burned, badly, on a 64 bit machine. Now sizeof(cellnode) is 16 bytes but sizeof(rownode) is 24.
Some other problems:
1. The element firstcell in struct rownode is typed as a pointer to a rownode structure. This should be a pointer to a cellnode structure.
2. The global variable head1. This, I think is the heart of your problem. Every row in a matrix should have its own linked list of cells. Do it right and there won't be global list of cells.
3. The global variable head2. What if someone wants to represent two sparse matrices? Global variables are not the way to go here. (They aren't the way to go in general.)
4. The lack of a structure to represent the matrix as a whole. Where are you capturing the fact that the matrix in question is a 20x50 sparse matrix? What if the next matrix to be dealt with is 50x10?
I modified my program as per your suggestion.
It works pretty good before the display() function is called, where it gives a segmentation fault. I spent hours debugging it but came up with no error.
Code:
#include <stdio.h>
#define MAX 20
static struct cellnode *a[MAX];
static int k=0;struct cellnode {
	int val;
	int col;
};struct rownode {
	int row;
	return new;
	return new;
struct cellnode * create_header(){
	struct cellnode *head;
	head=NULL;
	return head;
	new->val=v;
	new->col=c;
	new->nextcell=NULL;
	if(a[k]==NULL)
		a[k]=new;
	else{
		temp=a[k];
		temp->nextcell=new;
void link2(int r){
	new->row=r;
	new->firstcell=(struct rownode *)a[k];
	new->nextrow=NULL;
	if(head2==NULL)
		head2=new;
	else{
		temp=head2;
			temp=temp->nextrow;
		temp->nextrow=new;
void display() {
	struct cellnode *temp1;
	int i;
	for(i=0;i<MAX;i++){
		line1: temp1=a[i];
		if(a[i]==NULL){
		i++;
		goto line1;
		else{
		while(temp1->nextcell!=NULL)
			printf("%d %d\t",temp1->col,temp1->val);
			temp1=temp1->nextcell;
main(){
	FILE *fp1,*fp2;
	char i,c;
	a[k]=create_header();
	int n,col=0,row=0;
		fp1=fopen("1.txt","r");
		fp2=fopen("1.txt","r");
	if(fp1==NULL){
		return;
	while(((i=getc(fp1))!=EOF)){
	printf("%c",i);
	rewind(fp1);
//printf("row %d\n",row);
		//printf("%c",i);
		if(i==' ')
		i=getc(fp1);
		if(i=='\n'){
		//	printf("In IF loop");
                        link2(row);
		        col=0;
                        row++;
		//	printf("row %d\n",row);
			a[k++]=create_header();
		else {
			fscanf(fp2,"%d%c",&n,&c);
				if(n!=0){
					link1(n,col);
					printf("%d %d\t",n,col);
			col++;
	printf("\n");
	display();
If you have windows, try microsoft visual C++ express (it's free). It includes a source level debugger, that will show you what line caused the segmenation fault.
Abdul, if you have a tutoring center, a teaching assistant, or a professor that you can talk to, do so. Your coding needs a lot of help, more than we can give in forum.
You did not follow my advice. You still have global variables. You do not need any globals.
Some questions:
- What is the format of the data in the input file?
- How is it organized? (e.g., row major, column major, random?)
- What do you think should happen when you read a row/column/datum triple (or the equivalent) from the input file?
- Why made you think you need two FILE pointers?
This is an assignment, and my professors won't help.
I just used one global variable head2. That's how we did in class for a single linked list. Here we have a single linked list of rownodes.
D H said:
Some questions:
Attached is the .txt file containing input matrix.
Every time the end of a row is reached, i.e. a \n character in encountered,
link2 is called which adds a new node to the rownode linked list.
fp1 gets one character at a time and it keeps a track till EOF is reached. If I use fscanf with the same file pointer then I think some values will be skipped while traversing the matrix. Suppose getc(fp1) returns 1, then fscanf(fp1,"%d",n) will return the character/number after 1. This can be modified of course but I thought creating 2 file pointers will be convinient.
I got my code working.
Below if the final version.
If I need to improve on something please let me know.
Code:
#include <stdio.h>
#define MAX 20
static int k=0;
struct cellnode {
	int val;
	int col;
struct rownode {
	int row;
	return new;
	return new;
	head=NULL;
	return head;
	new->val=v;
	new->col=c;
	new->nextcell=NULL;
	if(a[k]==NULL)
		a[k]=new;
	else{
		temp=a[k];
		temp->nextcell=new;
void link2(int r){
	new->row=r;
	new->nextrow=NULL;
	if(head2==NULL)
		head2=new;
	else{
		temp=head2;
			temp=temp->nextrow;
		temp->nextrow=new;
void display() {
	struct rownode *temp2;
	int i=0;
	temp2=head2;
	while(i!=MAX){
		temp1=a[i];
		if(a[i]==NULL){
			i++;
			temp2=temp2->nextrow;
		else{
				printf("Row %d Col %d Val %d\n",temp2->row,temp1->col,temp1->val);
			i++;
main(){
	FILE *fp1,*fp2;
	char i,c;
	int n,col=0,row=0;
	if(fp1==NULL){
		return;
		printf("%c",i);
	rewind(fp1);
		if(i==' ')
			i=getc(fp1);
		if(i=='\n'){
                        link2(row);
		        col=0;
                        row++;
			k++;
		else{
			if(n!=0)
			link1(n,col);
			col++;
	printf("\n");
	display();
Abdul Quadeer said:
Code:
struct rownode {
	struct [B]rownode[/B] *firstcell;
Is firstcell a pointer to a rownode or a cellnode? You should fix this or change the name to firstrow.
Also you could use typedef's to avoid having to use "struct" so often:
Code:
typedef struct _cellnode {  /* underscore on struct name */
    int val;
    int col;
    struct _cellnode *nextcell;
}cellnode;                  /* no underscore on typedef name */
typedef struct _rownode {   /* underscore on struct name */
    int row;
    cellnode *firstcell;
    struct _rownode *nextrow;
}rownode;                   /* no underscore on typedef name */
rownode *head2 = NULL;
rownode *new;
    new = (rownode *)malloc(sizeof(rownode));
    return new;
firstcell is a pointer to the first non zero valued cellnode.
Thank you! I did not know that.
