Spatial separation of entangled particles implies physical separability?
40 replies · 4K views
aletheia
TL;DR
What demonstrates that spatially separated entangled particles are physically disconnected?
In experiments with entangled systems, the two subsystems can clearly become spatially separated and operationally distinguishable: they propagate to different locations, can be addressed by different apparatuses, and eventually produce separate local detection records.
For example, Hensen et al. describe entangled electron spins at sites separated by 1.3 km, while photon Bell experiments such as Rauch et al. enforce spacelike-separated measurement conditions.
Nonetheless, an entangled state is still represented before measurement as a joint nonfactorizable state.
So, what experimentally demonstrates that distinguishability and spatial separation necessarily imply complete physical disconnection of entangled particles?
What do you mean by "complete physical disconnection", and why do you think "distinguishability and spatial separation" would necessarily imply it?
As far as I can understand, in quantum entanglement, it seems to be assumed that the preparation of the entangled particles would physically disconnect them at the origin, therefore, creating the necessity for an additional explanation for their remaining correlation, which Einstein termed as “spooky action at distance”.
I wonder how the experiments and the theoretical and mathematical framework of quantum mechanics justify the premise that at preparation, by spatially separating and distinguishing the particles, there would also have been the full disconnection of the particles.
I mean: the factual results of the preparation are that they can become separate in space and can be distinguished and manipulated apart, but how experimentally is it known that the entangled particles have been fully physically disconnected one from the other?
I don’t think it would imply it.
If you mean they usually move away from the source in different directions, yes, that's a common feature of such experiments.
I'm not sure why you use the term "physically disconnect". What is that based on?
The explanation in QM is the wave function. Yes, Einstein did not like that explanation. But it's the only one we have.
Again, why do you think that is even a premise of QM at all? What is that based on?
Once more: why do you think they have? Where is that coming from?
Then why are you even asking the question at all? What prompted it? All this that you are saying about "fully physically disconnected" must have come from somewhere. Where?
Are you reading the EPR paper? It was an implicit assumption of EPR that sufficient spatial separation implies non-interaction. They basically argue that since the entangled particles are far apart from each other, they can not affect each other. This is manifest in special relativity as space like separated events are causally disconnected.
This implicit assumption was later caught by Bell and used in his theorem proving that QM does not satisfy (Bell-type) local causality.
It depends on what you mean by "full disconnection of the particles". I don't know what this means and I have not heard this terminology before.
Bell inequality violations are a result whereby correlations of specific measurements of (an ensemble of) two entangled particles carried out at space like separation are stronger than can be explained by a local hidden variable theory. Or, as Bell would say, a locally causal theory.
However, these correlations can not be used to actually send signals.
Do you count that as "fully physically disconnected" or not?
It's better to think in terms of Quantum Field Theory (QFT) for this one. Entangled particles are a single excitation of the field, so thinking in terms of two separate particles makes no sense. If you think of the quantum field, when one particle is detected, the entanglement is broken, and you have two separate excitations. I like to think of it like a stretched piece of elastic. Cut it, and you immediately get two pieces that are no longer stretched. Is it non-local in that picture? I think so, but others may like to debate it.
In QFT, since particles are excitations of the same underlying field permeating all space, 'disconnected' particles, IMHO, aren't the right way to describe what's happening - entangled or not.
Thanks
Bill
Hmmm, what are you counting as a "single excitation" here? If you hit the state with the number operator, you don't get 2?
You do get 2, but you can't split the state up into a product of two states each with a value 1 for the number operator. That's what it means for the state to be entangled.
Peter beat me to the punch - he often does o:)o:)o:)o:)o:)
Thanks
Bill
@PeterDonis @Matterwave
They state that the systems interact until T,
“[...] let us suppose that we have two systems, I and II, which we permit to interact from the time t =0 to t=T, after which time we suppose that there is no longer any interaction between the two parts.. [...]”,
without deriving it from the observations; then they use
“[...] since at the time of measurement the two systems no longer interact, no real change can take place in the second system in consequence of anything that may be done to the first system.[...]”
as a physical premise of the argument, thereby apparently not following their own earlier statement that
“[...] The elements of the physical reality [...] must be found by an appeal to results of experiments and measurements. [...]”,
since the assumed transition from interaction to non-interaction is not itself established there by experiment, nor derived from the quantum-mechanical formalism.
The question, therefore, is: what physically establishes the transition at T from an interacting joint system to two non-interacting systems?
Perhaps my use of the word “disconnection” was misleading indeed.
EPR made an implicit assumption in their argument that indeed you can stop the two particles from interacting with each other eventually. If the interaction never stops, their argument (that QM is incomplete) doesn't go through.
You could imagine shielding the particles from each other or separating them apart by vast distances. In EPRs working model, it would then be absurd to think that the two particles could still interact, affect, or disturb each other in any way. To do so would be "spooky action at a distance" which was absurd to Einstein.
But EPR's argument was faulty. They wrote their paper in 1935, way before Bell proved his inequalities (in the mid 60s) and before violations of Bell inequalities were shown by experiment (in 80s, 90s, 00s, 10s).
The general principle is that in QM the outcome is the eigenvector of the observable. Here it is a product state of 2 separate single particles.
This is the collapse of the wavefunction (or quantum field) that lies at the heart of QM. The cause is the interaction with whatever is doing the observing, etc.
You seem to be caught up in thinking of them as two interacting particles physically separated. They are not. When entangled, they can not be thought of as two particles, interacting, separated, or otherwise. As Peter pointed out, if the entangled state is 'asked' its particle number, you of course get 2, but that is all that can be inferred. This was, as @Matterwave pointed out, the error in EPR and the point Bell was making when talking about Bertlmann's socks.
Thanks
Bill
Not for the EPR state. It is still an entangled state and not a product state. When EPR says (something like) "after T, the two particles no longer interact" they mean something more akin to the Hamiltonian no longer having any interaction terms between the two particles (maybe because they got separated really really far from each other) and not that the state has collapsed into a product state.
EPR simply didn't notice they were sneaking in a locality assumption into their argument.
Wait a minute, if I remember correctly, EPR concerns that if you measure position or momentum, you can immediately predict the position or momentum of the other particle. This would seem to imply they are now separate particles and not entangled. What am I missing?
Of course they were sneaking in a locality assumption by thinking in terms of individual separate particles, which is something not implied by QM.
They said: 'If, without in any way disturbing a system, we can predict with certainty (i.e., with probability equal to unity) the value of a physical quantity, then there exists an element of reality corresponding to that quantity.' Measuring an entangled system disturbs the whole system. Again, I may be missing something.
Thanks
Bill
Thnks
Bill
Just the time order of things as the paper presents it. T is not the time of the measurement, it's the final time after which the entanglement is "locked in" so to speak. It is only after some more time, at a time ##t'>T## that the measurement happens.
The relevant quote (shortly after @aletheia provided quote):
We can then calculate with the help of Schroedinger's equation the state of the combined system I+II at any subsequent time; in particular, for any ##t>T##.
The EPR paper is always worth a (re)read 😉. It is a delightful paper, though it has its faults.
@Matterwave @bhobba
Thanks to you, we're closer to what I was actually asking.
“EPR made an implicit assumption in their argument that indeed you can stop the two particles from interacting with each other eventually. If the interaction never stops, their argument (that QM is incomplete) doesn't go through.”
Exactly — that’s the inference I was rejecting;
“You seem to be caught up in thinking of them as two interacting particles physically separated.”
Quite the contrary — that’s exactly the core of my question: why spatial separation and distinguishability should imply complete independence?
“the Hamiltonian no longer having any interaction terms between the two particle (maybe because they got separated really really far from each other)”
Maybe the error was to treat the disappearance of a direct interaction as implying complete physical independence, even though the entangled state itself remains joint.
I drew this image to better illustrate my question:
The red and blue would be the entangled particles, the gray, the preparation, and the green box points to the origin of the entangled pair at the preparation.
From my current understanding, the QM formalism does not seem to imply that preparation is followed by a complete physical separation of the entangled subsystems.
It establishes their distinguishability and allows their spatial separation, while the state itself remains joint and nonfactorizable.
My question is whether treating that spatial/dynamical separation as a complete physical independence could be precisely what creates the posterior “spooky” necessity to somehow reestablish a correlation that may never have been physically broken in the first place.
“For this purpose let us suppose that we have two systems, ##I## and ##II##, which we permit to interact from the time ##t=0## to ##t=T##, after which time we suppose that there is no longer any interaction between the two parts.”
This sloppy wording in the EPR paper simply tries to say: The mutual influence of distant systems by physical interactions can be ignored if they are sufficiently remote.
By "independence" here, do you mean statistical independence of measurements? In analyzing an argument such as EPRs, it is best if we stick to clear, well defined, and well scoped terminology.
For example, when EPR says "no longer any interaction", they don't mean measurements of the two particles will be statistically independent. Quite the contrary, their whole argument relies on perfect (anti) correlation.
Again, "complete physical independence" -- I don't know what (precisely) you mean by this.
EPR certainly understood that the entangled state persisted even after time ##T##. They need it for the rest of their argument.
But what they had in mind was to resolve the problem via some local hidden variables. Indeed, their entire argument was that the QM description of physical reality is incomplete (hence their title).
Local hidden variable theories were proven impossible later, as I noted in post #11.
Again, "complete physical separation" -- please precisely define your terminology.
Several issues here with shifting terminology.
I recommend reading the paper @bhobba referenced in post #12: "Bertleman's Socks and the Nature of Reality" by John Bell. It might prove illuminating.
@Matterwave @bhobba
From the Bertelsmann’s Socks and the Nature of Reality we have two useful images that I have edited to better illustrate my question.
First:
brings the assumption that at the preparation both particles are physically separated — meaning that they would have lost their previously joint state —, each of them as a complete whole on their own, which it seems (to me at least) an inference that both the experiments and the QM formalism don’t entitle.
Next we have
the questioning that EPR was advocating — that was later disprove by Bell’s inequality —, that both socks had to had their state predetermined before the measurement of any of them, as if knowing that one sock was pink that the other sock would be not-pink, therefore already having its own color already determined independently of the measurement of the other.
However, there might have been a premisse not fully investigated (at least I couldn’t find it anywhere).
Using the socks analogy: perhaps, if the particles still share their initial root, both of them would still “have the same color” (at least their shared state would still be “pink”) until one of them is measured — the moment which their bond is finalized ontologically —, leaving the other particle with both the consequences of their initial rooted state plus the physical separation.
Summarizing the analogy: the case is not that one sock was pink and the other was not pink, but rather that both were pink and at the measurement one is discovered as red leaving the other as white.
aletheia said:
First:
The figure is just a figure. It doesn't make any assumptions. It just shows you what the experiment is and what happens.
aletheia said:
Next we have
I'm unclear on what the highlighting of the pants means. The analogy is about socks.
Strictly speaking, Bell's inequalities didn't disprove local hidden variable (LHV) theories. They just put a bound on particular combinations of correlations of specific measurements of pairs of particles that any LHV theory must obey under a mild assumption of statistical independence of measurements.
It is only the later experimental proof that those inequalities are violated by nature that local hidden variable theories were disproved (barring any loopholes).
We usually call a theory such as this a LHV theory. It is what Einstein had in mind to avoid spooky action at a distance.
Did you try reading further into the paper?
The rest of your argument sounds like (an analogized and rather muddled version of) some of the arguments given by physicists that Bell directly addresses.
Yes, I did and it was insightful.
Even though I might not have been able to express me as clearly as I expected, your help along with the help from the other members has been very enlightening for my understanding of quantum mechanics.
Nevertheless, I’ll stop trying to push it further into my reasoning because it could be beyond the scope of the forum and I don’t mean to break any rules.
Your attention has been very much appreciated — whenever I need further clarifications from whom have deeper knowledge of the matter I’ll be back to bother you guys.
Thanks.
From my understanding without separation two particles would effectively have to occupy the same space, not possible
Do you have a link to a paper or textbook that makes this point? That would be a big help. Thank you.
Sure it is. If the particles are bosons, there's no problem at all. If the particles are fermions, there's no problem as long as they don't have the same spin.
Please cite a credible technical reference that states this.
Nothing. The EPR argument was that quantum mechanics is incomplete, meaning that there was some deeper theory in which each particle had its own position and momentum determined by the hidden variables of that deeper theory. With this theory in our hands we could treat the system as two independent particles both before and after the measurement that “breaks the entanglement”.
For what it is worth, much of the discussion that appear in the literature on this topic can be better understood by looking at the physical experiments. Many (if not most) of the EPR type experiments (to demonstrate the violation of the Bell inequality) are done with light. In such a case, the entangled state is produced with the aid of parametric down-conversion, which uses a nonlinear crystal. While the light is propagating in the crystal, it undergoes interactions, but when it leaves the crystal there is no more interaction: light does not interact when propagating through free space. After the crystal, the down-converted light is entangled. So, typically a pair of photons are produced that is entangled in some of their degrees of freedom. One can separate the pair of photons by sending them through a beam splitter. (Sometimes both would go the same way, but then it won't produce a coincidence detection which is readily discarded.) So, after the beam splitter, we have two photon that are not interacting, propagating in different directions toward separate detection systems, and yet, they are still entangled as demonstrated by the correlations in the measurements. So, entanglement has nothing to do with interaction, nor does it require the subsystems to be located at the same point.
It took me a long time to fully comprehend the QM terminology of what “separation” can mean in quantum entanglement; I would now distinguish at least ten notions of it:
  1. Spatial separation — A and B occupy distinct spatial regions.
  2. Operational distinguishability — A and B can be separately labelled, routed, manipulated or detected.
  3. Direct dynamical interaction — there is a direct A–B coupling affecting their joint dynamics.
  4. Dynamical decoupling / non-interaction — such a direct coupling is absent or negligible, e.g., Hint ≃ 0
  5. Jointness / nonfactorizability — the complete quantum state is not reducible to a product of subsystem states.
  6. Physical disconnection — some previously existing joint physical structure has actually ceased to obtain.
  7. Local real-state attribution — each spatially separated subsystem possesses or admits a real physical state of its own.
  8. Locality / real-state autonomy — what is done at A does not physically alter the real state at spacelike-separated B.
  9. Exhaustive ontological decomposition / supervenience — the states/properties of A and B plus their spacetime relations exhaust the physical state of the whole.
  10. Bell-local factorization — given a sufficiently complete λ, the joint probabilities factorize into local response probabilities.
These are obviously not synonyms.
In particular:
— spatial separation + distinguishability + dynamical decoupling ≠> physical disconnection ≠> exhaustive ontological decomposition.
There is also an important correction to how I formulated the issue earlier in this thread: Murgueitio Ramírez, in Separating Einstein’s Separability (2020), argues that Einsteinian separability should not be identified with supervenience.
So, today I’d put the question like this: which physical operation establishes the transition from an initially joint nonfactorizable structure to physical disconnection or to exhaustively independent local wholes?
Saying that the particles are spatially separated, separately addressable, and no longer directly interacting establishes 1, 2 and perhaps 4. The entangled state establishes 5. But I still do not see the inference that establishes 6 or 9.
That is, I think, a more precise version of the question I was trying — rather clumsily — to ask here early on.
