Special relativity and diffracting beams
  • Level: Undergrad
  • Thread starter calacone
calacone
Say there is a beam of light at 1 um (f=300 THz), and there is a particle traveling at constant speed along the axis of the beam, which is, say, a few mm or cm in diameter. Say the particle is going fast enough so that the shift brings the light down to the MHz level (v/c ~ 1- O(10^-16)). Then the wavelength as measured by the particle will be something like a few hundred meters. But how can this happen, if the beam is localized in the transverse direction at the mm or cm level?
If it is a gaussian beam, then I think the beam divergence would make the beam appear consistent with the wavelength observed by the particle, even if the beam divergence is small in our rest frame (I haven't checked this). What about diffraction free beams? Or other odd arrangements that allow the particle to see a highly localized spot at MHz frequencies (say, focusing mirrors spaced periodically along the axis of the beam path but offset to either side, so that the beam periodically intercepts the path of the particle, or something like this).
(sorry in advance for not checking the math, nor checking previous forum posts for similar questions)
Long wavelength and small bundle beam are compatible.
The Abbe diffraction limit assumes an isotropic wavelength. The relativistic movement of a reference frame in longitudinal direction does not change the wavelength in transverse direction.
If the beam is not perfectly collinear, the beam has a wider angle in the rest-frame of the moving particle, due to the (inverse) relativistic headlight effect (aberration).
I think this phenomenon will occur with any wave, such as sound. The small diameter wavefront seen at optical frequencies may be considered as arising from the superimposition of wavelets from an infinitely wide wavefront. This is Huygens' Principle at work. If you now travel along the beam, the waves as observed are longer; in other words, you need to travel further for a given phase shift. The waves from the outer Huygens' Sources are also longer, so there is less phase difference as we move off axis. So I think you will observe a broader beam. The beam will diverge at a greater angle than the original optical beam. In essence, I am suggesting that the entire space is filled with the optical energy, even though you see a narrow cone, and when you travel along the beam there will be created a broader beam by the process of superimposition.
