- 29,796
- 21,621
Too many words. Time for some mathematics!
No. An event happens at a place and time. The Earth and the dwarf planet aren't at the same point in space at the same time so they can't be described by the same event.AronYstad said:What I'm trying to say is, can't the situation be described as two events which are that the Earth and dwarf planet move together?
It's worth pointing out that this applies to classical physics as well as SR. This is valid whatever the speed of the rocket. In the classical, non-relativistic case (where the rocket has a speed much less than the speed of light), we have ##T = T_0##. That's the Galilean time transformation - which is simple as there is assumed to be a single universal time in non-relativistic physics.vela said:No. An event happens at a place and time. The Earth and the dwarf planet aren't at the same point in space at the same time so they can't be described by the same event.
Kalle's perspective:
Lisa's perspective:
- Event 1: Lisa leaves Earth (##x=0##) at t=0.
- Event 2: Lisa arrives at the dwarf planet (##x=D##) at ##t=T## (different place and time).
- Event 1: Earth leaves Lisa (##x'=0##) at t'=0.
- Event 2: Dwarf planet arrives at Lisa (##x'=0##) at ##t'=T_0## (same place, but different time).
What I meant was that since we describe everything on Earth as one object, Earth, then, since the Earth and the dwarf planet have the same reference frame and velocity, why can't we describe them as one single object.vela said:No. An event happens at a place and time. The Earth and the dwarf planet aren't at the same point in space at the same time so they can't be described by the same event.
Lisa's perspective:
In this problem, you can treat the Earth and the dwarf planet as points in space because they're very small compared to the relevant length scale. The Earth's radius, for example, is about 6400 km, which is much smaller than the distance Lisa travels, which will be on the order of an astronomical unit, which is approximately 150,000,000 km.AronYstad said:What I meant was that since we describe everything on Earth as one object, Earth, then, since the Earth and the dwarf planet have the same reference frame and velocity, why can't we describe them as one single object.
You can treat them as a single body. An body with a non-negligible spatial extent. An "extended body" if you will. As opposed to a "pointlike object".AronYstad said:What I meant was that since we describe everything on Earth as one object, Earth, then, since the Earth and the dwarf planet have the same reference frame and velocity, why can't we describe them as one single object.
