Specialy theory of relativity [Answer Check]
The problem involves a scenario in special relativity where a 30-year-old astronaut travels to a star 40 light-years away at a speed of 0.90c, leaving her newborn child on Earth. The discussion centers on calculating the ages of both the astronaut and her child upon her return.
  • Participants discuss the application of time dilation equations and the interpretation of time experienced by the astronaut versus the child. There are attempts to calculate the total time for the journey and the resulting ages, with some questioning the correctness of the calculations and assumptions made.
The discussion is ongoing, with various interpretations of the calculations being explored. Some participants have offered guidance on re-evaluating the approach and checking the application of formulas. There is no explicit consensus on the final ages, and participants are encouraged to revisit their calculations for accuracy.
Participants note potential errors in the initial calculations and emphasize the importance of considering the reference frames of both the astronaut and the child. There is mention of the need for precision in determining the child's age, suggesting that the initial assumption of 88 years may not be entirely accurate.
AClass
a 30-year old female astronaut leaves her newborn child on Earth and goes on a round-trip voyage to a star that is 40light-years away in a spaceship traveling at 0.90c. what will be the ages of the astronaut and her son when she returns?
[tex]\Delta[/tex] t = [tex]\frac{\Delta t_o}{\sqrt{1 - \frac{ v^2 }{ c^2 }}}[/tex]
40 years (2) +(0.20)(40 years)= 88 years
The astronaut will be 30+88 years = 118 years old when she returns
Using the above equation.
[tex]\Delta[/tex] t = 118 years
v=0.90c
Obtained [tex]\Delta t_o[/tex] = 51.44 years
The astronaut's son will be 51 years old when she returns.
Wondering if I did this correct, I don't have any answers to check from It looks right to me.
Ummm, I'm not following you there. :rolleyes:
Something went wrong again. You're not applying the right time to the right person.
You might want to just start in the child's frame of reference. Then use x = vt for that frame.
v=0.90c
No, that's not the right application of the formulas.
For starters, the astronaut will age the slowest.
Means, the parent is on route for 80 years [40 Years there, then 40 years back], plus since she is traveling 10% slower than the speed of light 20% slower since she is going there and back.
I realize where I went wrong. I went to verify my notes.
The child will be 88 years old.
[tex]\Delta[/tex] t = 88 years [Earth Observer]
Using the equation,
Obtained [tex]\Delta t_o[/tex] = 38.36 Years
Therefore the child will be 88 years old, and the parent will be [30 years+38.36 years] 68 years old.
That should be right. Thanks for the help!
That's not the correct math. :rolleyes:
Please, start over. First calculate the total distance (in light years). Then write down the velocity (v = 0.90c). It's also helpful to note that c = 1 ly/y. Now go back to one of your most basic kinematics equations for a uniform velocity, x = vt. Solve for t.
Using the equation,
That's almost right. But you should go back and redo the child's age for better precision. It's not exactly 88 years. :wink:
