What Is an Example of a Linear Map on R^4 Meeting Specific Dimensional Criteria?
An operator T on R^4 can be defined as T(w, x, y, z) = (w, 0, x, 0) to meet specific dimensional criteria. This operator satisfies the conditions that the dimension of the null space and the range are both equal to 2, fulfilling the requirement that dim(nullT) = dim(rangeT). Additionally, the intersection of the null space and the range has a dimension of 1, as they share one vector in common. The basis vectors can be expressed as {e1, e2, e3, e4}, where T(e1) = e1, T(e2) = 0, T(e3) = e2, and T(e4) = 0. This example effectively illustrates the properties of linear maps in R^4.
*melinda*
Give a specific example of an operator T on R^4 such that,
1. dim(nullT) = dim(rangeT) and
2. dim(the intersection of nullT and rangeT) = 1
The attempt at a solution
I know that dim(R^4) = dim(nullT) + dim(rangeT) = 4, so dim(nullT) = dim(rangeT) = 2.
I also know that nullT will have 2 basis vectors and rangeT will also have 2 basis vectors (so that 1. is satisfied), and that they must have one vector in common (so that 2. is satisfied).
I started with T(w, x, y, z) = (w, x, 0, 0), but that only does it halfway.
I just don't know how to generate an example that satisfies both conditions.
Any ideas?
Try T(w,x,y,z)=(w,0,x,0). This is somewhat confusing because you usually think of null(T) and range(T) as living in different spaces. Write it in terms of a basis {e1,e2,e2,e4}. T(e1)=e1, T(e2)=0, T(e3)=e2, T(e4)=0. So null(T)=span(e2,e4). range(T)=span(e1,e2).
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
11K
