Speed of Earth at 41 degrees North.
The speed of the Earth at the equator is approximately 1,670 km/hr, calculated using the formula for circumference (2πr) divided by 24 hours. For a location at 41 degrees North, the radius must be determined using trigonometric principles, specifically the cosine function. The correct formula for the radius at 41 degrees North is x = 6370 * cos(41 degrees), leading to a speed calculation that should yield a value less than that at the equator. The discussion also highlights the use of LaTeX for formatting equations in online forums.
  • Understanding of Earth's radius and circumference calculations
  • Basic trigonometry, specifically cosine functions
  • Familiarity with LaTeX for typesetting mathematical equations
  • Knowledge of angular measurements in degrees
  • Learn how to calculate the circumference of a circle at different latitudes
  • Study the properties of right triangles and their applications in trigonometry
  • Explore advanced LaTeX techniques for mathematical documentation
  • Investigate the effects of Earth's rotation on speed at various latitudes
Students in physics or mathematics, educators teaching geometry and trigonometry, and anyone interested in understanding Earth's rotational dynamics and mathematical equation formatting.
hawk320
The Earth's radius is 6370 km, if you are sitting in a classroom on the equator how quickly would you be traveling? If you were in NY which has a latitude of 41 degrees N, how quickly would you be traveling?
2(pi)r=circumference
I understand that you need to find the circumference and divide it by 24(hours). This gives you km/hr. So at the equator you would be going t about 1.67 * 10^3 km/hr. I don't understand how to find the circumference at 41 degrees N.
Think of the Earth as being made up of a whole lot of circles stacked on top of one another. The largest circle is the one at the equator, whose circumference you already found. The circle at 41 degrees north is smaller, and has a smaller radius correct? Now all you need is this radius. In order to find it, you are going to needs that angle.
HINT: Think triangles. Draw a circle representing the Earth. Now, draw in the radius at the equator and a smaller line above it representing the radius at 41 degrees north of the equator. Can you relate the lengths of these two radii using that angle of 41 degrees?
It would be the x-component of a vector with length the radius of the Earth and inclined 41 degrees to the x-axis. Can you find that?
I tried doing it as a right triangle which gave me the equation x(the radius at 41 degrees)= 6370/cos(41 degrees). The problem with that is that I get the speed of it to be 2.21 * 10^3km/hr, which is faster than at the equator. Which I believe is not possible because the equator should be the fastest (unless I am wrong about that).
The Earth's radius is the hyptenuse of your triangle. cos(theta)=adjacent/hypotenuse. The cos function shouldn't be in the denominator.
I got that from cos41 = 6730/x which is equal to cos41x = 6730 which is then equal to x=6730/cos41.
The adjacent side here is x. Your equation should read:
\cos 41 =\frac{x}{6730}
I think you may have your angle in the wrong place. The angle of 41 degrees is between the horizontal (equator line on that circle representing the Earth) and the hypotenuse. Then, using the properties of parallel lines, the angle in the triangle adjacent to the "x" side would also be 41 degrees.
No, remember the 41deg is the angle between the equator(horizontal) and the line to the latitude of your classroom.
So cos41 = adjacent/hypotonuse = x/ radius
Thank you, the problem I was having was that I was solving for the wrong radius. Also what program do you use to type up the equations?
Anytime. Glad you figured it out. :smile:
LaTex. There is a template in the menu above. It appears as a Summation symbol (sigma).
You can also click on any equation in any thread and a new window will open with the codes. That is how I am learning Latex. I think there is a thread where you can test your code using skills somewhere. I'll look around for it.
Casey
Casey
Thank you, that will make writing equations a lot easier.
  • · Replies 32 ·
