How can I split up a long and complicated equation in LaTeX?
  • Context: LaTeX
  • Thread starter Thread starter SeM
    Latex Lines Split
The discussion focuses on splitting a complex equation in LaTeX to prevent it from exceeding the right margin. Users recommend utilizing the split environment within an equation or align environment for better formatting. The IEEEeqnarray environment is also suggested for clearer presentation of multiple equations. Additionally, using variables to simplify the equation structure enhances readability and organization.
  • Familiarity with LaTeX typesetting
  • Understanding of the amsmath package
  • Knowledge of the split and align environments
  • Experience with the IEEEtrantools package for advanced formatting
  • Learn how to implement the split environment in LaTeX documents
  • Explore the IEEEeqnarray environment for multi-line equations
  • Research best practices for variable usage in complex equations
  • Review the amsmath documentation for advanced equation formatting techniques
Mathematicians, physicists, and researchers who frequently work with complex equations in LaTeX and seek to improve the clarity and presentation of their mathematical expressions.
SeM
Hi, how do I split up this horrible equation into several lines?
given in latex code:
\Psi_2= -2.018\,{10}^{-122}\,C_{2}\,{\mathrm{e}}^{-x\,1.014{}{10}^7{}\mathrm{i}}\,\left(1.398\,{10}^{121}\,{\mathrm{e}}^{x\,1.014{}{10}^7{}\mathrm{i}}-1.398\,{10}^{121}\,x^2\,{\mathrm{e}}^{x\,1.014{}{10}^7{}\mathrm{i}}+1.398\,{10}^{121}\,x^2-1.436\,{10}^{135}+x^3\,1.396{}{10}^{60}{}\mathrm{i}+x\,2.833{}{10}^{128}{}\mathrm{i}\right)
and shown in latex form:
\begin{equation}
\end{equation}
it shows beautifully here, but in my latex document it stretches beyond the right margin of the page, and does not split up no matter what I have tried.
What have you tried?
I managed, I used
\begin{equation*}
\begin{split*}
\begin{align*}
& Text to split //
& second part to split //
& and so on //
\end{equation*}
\end{split*}
\end{align*}
It is strange to see an align within a split. Normally, it should be inside the align. From the AMS math documentation:
Like multiline, the split environment is for single equations that are too long to fit on one line and hence must be split into multiple lines. Unlike multline, however, the split environment provides for alignment among the split lines, using & to mark alignment points. Unlike the other amsmath equation structures, the split environment provides no numbering, because it is intended to be used only inside some other displayed equation structure, usually an equation, align, or gather environment, which provides the numbering.
It worked well as given.
Thanks!
\begin{equation}
\end{equation}
Well there are various environments like align and IEEEeqnarray that you could use to produce output like this: $$\begin{align}
\Psi_2 = -2.018 \, {10}^{-122} \, C_{2} \,
{\mathrm{e}}^{-x\,1.014 \cdot {10}^7{}\mathrm{i}}\, \Bigl(
& 1.398 \, {10}^{121} \,
{\mathrm{e}}^{x\,1.014 \cdot {10}^7{}\mathrm{i}} \nonumber \\
&-\> 1.398 \, {10}^{121} \, x^2 \,
{\mathrm{e}}^{x \, 1.014 \cdot {10}^7{}\mathrm{i}} \nonumber \\
&+\> 1.398\,{10}^{121}\,x^2 - 1.436\,{10}^{135} \nonumber \\
&+\> x^3\,1.396{}{10}^{60}{}\mathrm{i}
+ x\,2.833{}{10}^{128}{}\mathrm{i} \Bigr) \,.
\end{align}$$
But why not just use a few variables: $$\Psi_{2} = - \lambda \, C_{2} \,
\mathrm{e}^{-\mathrm{i} \phi x} \, \Bigl(
\alpha \mathrm{e}^{\mathrm{i} \phi x}
- \alpha x^{2} \mathrm{e}^{\mathrm{i} \phi x}
+ \alpha x^{2} - \beta
+ \mathrm{i} \gamma x^{3}
+ \mathrm{i} \delta x \Bigr) \,,$$ where $$\begin{eqnarray}
\lambda &=& 2.018 \cdot 10^{-122} \,, &\qquad&
\phi &=& 1.014 \cdot 10^{7} \,, \\
\alpha &=& 1.398 \cdot 10^{121} \,, &&
\beta &=& 1.436 \cdot 10^{135} \,, \\
\gamma &=& 1.396 \cdot 10^{60} \,, &&
\delta &=& 2.833 \cdot 10^{128} \,.
\end{eqnarray}$$ This makes the structure of the equation so much clearer.
You can produce the second set of equations in a paper with, e.g.,
Code:
\begin{IEEEeqnarray}{rCl+rCl}
\end{IEEEeqnarray}
(If you want to use the IEEEeqnarray environment like here then install IEEEtrantools and put \usepackage[retainorgcmds]{IEEEtrantools} in the document preamble.)
Thanks WLE! I ended up using texlabel because these expressions become too long.
25K
