Spring constant of a horizontal wire
In summary: The equation for a spring in an elastic range is: mg=kx(1-e-ΔL/L), where k is the spring constant, x is the distance from the equilibrium position, and ε is the modulus of elasticity.The equation for a spring in an elastic range is: mg=kx(1-e-ΔL/L), where k is the spring constant, x is the distance from the equilibrium position, and ε is the modulus of elasticity.Syd has provided a good summary of the content.
Syd096
When a mass "m" is hung from the centre of a horizontal wire, length "L". How far will the centre of the wire stretch downwards, in terms of m, L, E (youngs modulus) and A (cross sectional area of wire)
mg = Tcosθ
When m is the mass hung from the wire
And T is tension in the wire
F=EAΔL/Lo
Where E is youngs modulus
F will be the tension in the wire?
ΔL is the amount the wire stretches
Lo is the original length of wire
mg = Tcosθ
T=mg/cosθ
mg/cosθ=EAΔL/Lo
but is it posible to change this equation so it is only in terms M,Lo,E,A
Or find the effective spring constant of the wire
This can be a wickedly hard problem. How tight is the horizontal wire before the mass is hung on it?
No value given. Possible add another variable (Original tension)
Syd, welcome to PF!
I have a few comments and questions.
1. It sounds like we assume zero tension initially, since none was given.
2. How are you defining θ? I'm guessing it's the angle of the wire w.r.t. horizontal, but I'm having trouble with this equation:
mg = Tcosθ
Did you draw a free-body diagram first? How many forces does it have?
3. After eliminating T, we are left with 2 unknowns, θ and ΔL. Can you find another equation (using geometry) to relate them?
Also note that the linear stress-strain relation is only valid within the elastic regime, which means that it is typically applied for very small values of ΔL/L (ΔL/L<<1).
It is a spring only withing the elastic range, so by definition, asking for a spring constant restricts the discussion to the linear elastic range.
Draw the picture, first with the wire horizontal and then with the wire stretched to the extended position with the weight in place. Then think about how much the wire has been stretched, and also draw an FBD in the drooped position.
There is no reason to speak in terms of a spring constant if the stress-strain relation is used (and required by the problem statement). Linearity and smallness are typical assumption that the OP needs to be aware of; the spring constant is not.
Actually, the linear range is a part of the stress-strain relation.
If you mean "the stress-strain relation" that Syd should probably use in the solution, then I agree. If you mean "the" general "stress-strain relation", then I disagree.
1. What is the definition of spring constant?
The spring constant, also known as the force constant, is a measure of the stiffness of a spring. It represents the amount of force required to stretch or compress a spring by a certain distance.
2. How is the spring constant of a horizontal wire determined?
The spring constant of a horizontal wire can be determined by using Hooke's Law, which states that the force applied to a spring is directly proportional to the distance it is stretched or compressed. By measuring the force and displacement of the wire, the spring constant can be calculated.
3. What factors can affect the spring constant of a horizontal wire?
The spring constant of a horizontal wire can be affected by the material of the wire, its length, and its cross-sectional area. The temperature and tension of the wire can also impact the spring constant.
4. How does the spring constant affect the behavior of a horizontal wire?
The spring constant determines the stiffness of the wire, which affects its elasticity and ability to resist deformation. A higher spring constant means the wire will be more difficult to stretch or compress, while a lower spring constant indicates a more flexible wire.
5. Can the spring constant change over time?
Yes, the spring constant can change over time due to factors such as wear and tear, changes in temperature, or changes in the tension of the wire. It is important to regularly check and adjust the spring constant of a horizontal wire to ensure accurate results in experiments and calculations.
