How Do You Calculate the Spring Constant of a Charged DNA Molecule?
To calculate the spring constant of a charged DNA molecule, the effective distance between the ends must account for a 0.4% compression of its original length of 1.12 μm, resulting in a compressed length of approximately 1.11552 μm. The electrostatic force is calculated using Coulomb's law, with the Coulomb constant and the charges involved. The relationship between the electrostatic force and the spring force is established through Hooke's law, where the spring constant k is derived from the force divided by the compression distance. The correct compression distance x is determined to be 0.004 times the original length, not the compressed length itself. Ultimately, the spring constant is calculated to be approximately 1.685 x 10^9 N/m.
bastige
A molecule of DNA lies along a straight line. It is 1.12 μm long. The ends of the molecule become singly ionized; negative on one end, positive on the other. The helical molecule acts as a spring and compresses .4% upon becoming charged.
The Coulomb constant is 8.99 X 109 N*m2/C2.
Determine the effective spring constant of the molecule. Take into account the compressed length when calculating the distance between the ends of the molecule. Answer in units N/m.
Fe= ke * ( q1q2 / d^2 )
d = 1.2*10-6 - (1.2*10-6 * .004) = 1.1952 μm
Fe = ke * ( q1q2 / d2 ) = (8.99*109) * (( 1.6*10-19 )2) / (1.1952*10-6)2 = 2014 N
Fs = kx
x = d
Fe = Fs ---> 2014 = (1.1952*10-6) k ---> k = 1.685*109 N/m
Is the distance 1.2 or 1.12 μm?
Fs = kx
x = d
In Hooke's law (F = kx), x is the amount of compression from the uncompressed/unstretched position. So x does not equal d!
distance is 1.12μm , so
d=(1.12E-9) - (1.2E-9 * .004) =1.11552E-9
& i totally butchered the rest. I'm not sure what its supposed to look like
Fe=8.99E+9 * ? / 1.11552E-9
Then
Fs=kx
Fs*x =K
Good.
You had the right idea before:
F_e = k_e q^2/d^2
Then
Fs=kx
Fs*x =K
F = kx
so, k = F/x.
What's x? (By what distance is the "spring" compressed?)
This guy is right. x does not equal d. x equals (1.12 μm*.004)
9K
