Hooke's Law: Spring Force Negative?
Hooke's Law states that the force exerted by a spring is given by F = -kx, where k is the spring constant and x is the displacement from equilibrium. The negative sign indicates that the force acts in the opposite direction of the displacement. While the force value can be negative, its magnitude is always positive, and it can be expressed as |F|. When discussing vectors, the negative value signifies direction rather than a negative magnitude. Understanding this distinction clarifies the behavior of forces in spring systems.
Mouadys
Hello,
Following Hooke's law, the force applied by a string on an object attached to one of its ends is F = -kx
But here is my question : if we consider the equilibrium coordinate x=0 of a horizontal string, and the string is stretched until its end reaches a coordinate x1>0. By applying hooke's law we find F = -k*x1 but since x1>0 so that means F<0, but as I know the magnitude of a force cannot be negative...so am I missing something or should I use |F| for magnitude or what ?
Thank you
Mouadys said:
Hello,
Thank you
Welcome to the PF.
Of course it can. It all depends on coordinates. Have you learned about vectors yet? (Vectors have a magnitude and a direction). :smile:
##\vec F=-k(\vec x-\vec x_{eqbm})##
Likes berkeman
Welcome to the PF.
Thank you for answering.
In fact, yes I have learned about vectors but I personally have never seen a negative magnitude, and since as I have studied the magnitude of a vector is ||F|| = sqrt(Fx^2 + Fy^2 ...) so doesn't this basically mean the magnitude of F is |Fx| ? ( Fx = -kx)
Just think about a mass initially at x=0 with a spring that goes off to the left. It is on a frictionless horizontal surface.
You pull the mass out to the right at x=1cm and let it go. What happens next?
It just goes back to x=0 (and negative values depending on k) under the effect of a force directed from right to left.
If it rests on a frictionless surface, it oscillates back and forth to +/- 1cm. What are the forces on the mass as it oscillates? Include the magnitude of the force in the x direction... :smile:
So what direction must the force point for that to happen?
It goes from the right to the left, and I get that spring force has an opposite direction of the stretching/compression.
What worries me is getting a force with a negative value, which is something I have never seen, as I always hear that the magnitude of a force is always positive.
That is what the negative sign means. The negative of a vector simply points in the opposite direction.
That is true. The magnitude of x is the same as the magnitude of -x and both are positive.
Then how would I explain a stretch of x=1m to result in a positive force magnitude ?
Let's take K=2N/m
F = -2*1=-2N
It gives a negative value
Whilst with x=-1 F=2N
So am I supposed to use |F| to write magnitude or what ?
Let's take K=2N/m
F = -2*1=-2N
Remember that force is a vector. So a force of -2 N is a force of magnitude 2 N pointing in the -x direction. Properly it should be written as F = (-2,0,0) N to make it clear that it is a vector, but in this case the 0 components are supposed to be understood from the context.
And, yes, if you want to show the magnitude of a force you can write |F|. In this case that would be |(-2,0,0)| = 2.
Now I got it thank you very much for your support.
