Spring SHM Homework: Solving for Displacement of a Suspended Point Mass
A point mass of 20 kg is suspended by a massless spring with a constant of 2000 N/m, released from an elongation of 15 cm. The discussion centers on deriving the equation of motion for the mass, considering gravitational potential energy and spring potential energy. Key points include defining the equilibrium position, calculating angular frequency (ω = 10 rad/s), and determining the amplitude of oscillation as 0.05 m. The final equation of motion is expressed as x(t) = 0.05 cos(10t), indicating displacement from the equilibrium position. The discussion emphasizes the importance of understanding the relationship between displacement, amplitude, and equilibrium in simple harmonic motion.
Suyash Singh
A point mass m= 20 kg, is suspended by a
massless spring of constant 2000 N/m. The
point mass is released when elongation in
the spring is 15 cm. The equation of
displacement of particle as function of time
is : (Take g = 10 m/s2)
A is amplitude
w is omega
t is time
k is spring constant
PE= 1/2 m A^2 w^2 cos^2(wt+ phi)
PE=1/2Kx^2
equating these two equations doesn't do anything so how do i proceed?
Suyash Singh said:
doesnt do anything
Can you elaborate ? What is ##\omega## ? What is PE in the first equation ?
It does if you consider specific values of x and t, i.e. the boundary conditions.
You will also need more equations since you have three unknowns to pin down.
Likes BvU
s
omega is angular velocity
PE is potential enrergy
i really don't know what to do
So you want to find the equation of motion? Don't forget that the mechanical energy is being affected by gravity as well as the spring. So PEgravity=mgx
You only used the kinetic energy and spring potential energy.
Likes Suyash Singh
What do you know about x, ##\dot x## and P when t=0?
Likes Suyash Singh
when t=0 x=15
dont know what is x dot(if it is omega then i don't know how to find it)
PE=1/2 2000 (15/100)^2
=1000 x 225/10000
22.5 joules
but i don't know the distance from ground so PEgravity=??
Here is what I would do. Just keep in mind that I only have the knowledge of a first year physics student
Particle executes SHM ∴
x(t)=xmcos(ωt-θ)
v(t)=-ωxmsin(ωt-θ)
a(t)=-ω2xmcos(ωt-θ)
F=ma => -1/2kxm2=m(-ω2xm) => ω=√k/m=10rad/s
x̶[̶S̶U̶B̶]̶m̶[̶/̶S̶U̶B̶]̶=̶0̶.̶0̶1̶5̶m̶, ω=10rad/s
v̶(̶0̶)̶/̶x̶(̶0̶)̶=̶-̶ω̶x̶[̶S̶U̶B̶]̶m̶[̶/̶S̶U̶B̶]̶s̶i̶n̶θ̶/̶x̶[̶S̶U̶B̶]̶m̶[̶/̶S̶U̶B̶]̶c̶o̶s̶θ̶=̶-̶ω̶t̶a̶n̶θ̶ ̶=̶>̶ ̶t̶a̶n̶θ̶=̶-̶(̶(̶v̶(̶0̶)̶/̶x̶(̶0̶)̶)̶/̶ω̶)̶ ̶=̶>̶ ̶θ̶=̶t̶a̶n̶[̶S̶U̶P̶]̶-̶1̶[̶/̶S̶U̶P̶]̶-̶(̶(̶v̶(̶0̶)̶/̶x̶(̶0̶)̶)̶/̶ω̶)̶ ̶s̶i̶n̶c̶e̶ ̶x̶(̶0̶)̶ ̶a̶n̶d̶ ̶v̶(̶0̶)̶ ̶a̶r̶e̶ ̶u̶n̶k̶n̶o̶w̶n̶ ̶t̶h̶i̶s̶ ̶m̶e̶t̶h̶o̶d̶ ̶f̶a̶i̶l̶s̶.̶ ̶ ̶∴̶x̶(̶t̶)̶=̶0̶.̶0̶1̶5̶m̶c̶o̶s̶(̶1̶0̶(̶r̶a̶d̶/̶s̶)̶t̶-̶θ̶)̶ ̶w̶h̶e̶r̶e̶ ̶o̶n̶l̶y̶ ̶θ̶ ̶i̶s̶ ̶l̶e̶f̶t̶ ̶u̶n̶k̶n̶o̶w̶n̶.̶ ̶T̶h̶i̶s̶ ̶i̶s̶ ̶a̶l̶l̶ ̶a̶s̶s̶u̶m̶i̶n̶g̶ ̶t̶h̶a̶t̶ ̶x̶[̶S̶U̶B̶]̶m̶[̶/̶S̶U̶B̶]̶=̶1̶5̶c̶m̶
There's a solution for this on https://www.hashlearn.com/questions/study_levels/class-xi/exams/engineering-entrance/subjects/physics/topics/oscillations-and-waves/challenges/point-mass-20-kg-suspended-massless-spring-constant-2000-nm-point-mass-released-elongat-aa4b9c6 but need to pay to see. If you're really desperate... I still wouldn't pay for that kind of information (should totally be free).
Also if you are using the mechanical energy the height for mgh would just be the distance x that is given when the particle is back at 0 potential spring energy and 0 when its first released.
Likes Suyash Singh
Suyash Singh said:
when t=0 x=15
First, need to define x. You need to specify where 0 is (bearing in mind that you have to match it with an SHM expression) and whether up is positive or negative.
If x is displacement, what is dx/dt? What is its value when the mass is released?
Likes Suyash Singh
x(t)=xmcos(ωt-θ)
v(t)=-ωxmsin(ωt-θ)
a(t)=-ω2xmcos(ωt-θ)
xm=0.015m, ω=10rad/s
Its ok cause its a school problem
ok so omega, x are known now
i need phi and amplitude
x(t)=xsin(wt+ phi)
at t=0
15=15sin(phi)
phi=90 degrees
x(t)=15sin(10t+90)=15cos(10t)
similarly for others
v(t)=-150sin(10t)
a(t)=-1500cos(10t)
x is displacement
x=0 is the condition when mass is not present on spring
down is positive cause its more convienient this way here
dx/dt is velocity
mass released then velocity=0 m/s cause of the above equation which i wrote in post #12
For the standard SHM equation you need the displacement from the equilibrium position. Otherwise you will need to add a constant term.
So think again about the amplitude.
Likes Suyash Singh
but the three equations i got in post no 12 are they sufficient to find the solution?
is the amplitude 15cm?
but what is amplitude really here?
i mean not the value but the meaning of the term
in waves it is the up and down distance but here?
In SHM the amplitude is the maximum displacement each side from a central equilibrium position.
Where is the equilibrium position in this case?
If you draw a diagram of the motion of the mass you'll see the 15cm distance that the spring was stretched is greater than the distance from the equilibrium position to the fully stretched position. So the given distance x=15cm is greater than xm.
But you do know the distance x=15cm so you may be able to solve for xm with the mechanical energy at those two positions.
force=kx
mg/k=x
x=200/2000
x=0.1m
equilibrium position is 0.1 m
Ok, so what is the initial displacement from equilibrium (i.e., the amplitude)?
0.15m-0.1m=0.05m
amplitude=0.05m
Suyash Singh said:
0.15m-0.1m=0.05m
amplitude=0.05m
Right, so can you now write the complete expression? Don't forget to specify what your x represents.
Likes Suyash Singh
x(t)=0.05sin(10t)
x is displacement from equilibrium
Suyash Singh said:
x(t)=0.05sin(10t)
Does that give the right displacement at t=0?
displacement at t=0 is -0.1 m
oh :(
x(t)=0.05sin(10t) - 0.1
oh :(
No, now you do not have it symmetric about x=0. Look back at your post #12. There is something there you have forgotten.
And it is the displacement from equilibrium position that is of interest. What is the initial displacement?
x(t)=Asin(wt+phi)
at t=0
displacement from equilibrium is 0.05m
so
0.05=0.05sin(phi)
thus phi=90 degrees
x(t)=0.05sin(10t+90)
x(t)=0.05cos(10t)
Suyash Singh said:
x(t)=Asin(wt+phi)
at t=0
so
0.05=0.05sin(phi)
thus phi=90 degrees
x(t)=0.05cos(10t)
Yes!
Likes Suyash Singh
  • · Replies 20 ·
