Spur gear selection for parallel shafts
  • Thread starter Thread starter novato
    Gear Parallel
4 replies · 4K views
novato
Hi,
I have a DC motor with 4mm diameter shaft, flat tip.
How can I attach a 12 teeth pinion to this drive shaft?. I have been loking for pinions and gears on the web but they don't specify how are they attached to a shaft, as there are round shafts and flat tip shafts. Do I have to ask for gears with hub and set screw?
Any help would be very appreciated.
Novato
There are many ways to do it, one of the simplest would be a set screw in the gear's hub, like on this W.M.Berg gear:
http://www.wmberg.com/catalog/photos/B05B065.jpg
http://www.wmberg.com/catalog/productsearch.aspx?url=http://wmberg.smartcats.com/sc_app/default.asp
The set screw is a good option but, is there any stainless steel gear that matches a flat tip shaft like this?
Your question doesn't make a whole lot of sense. The flat is made for the set screw. Who/what are stanley steel gears?
Thank you. I have seen some gears that have an opposite shape for flat tip shafts.
PD: I'm sorry about the bad spelling.
