Spur gear selection for parallel shafts
  • Thread starter Thread starter novato
    Gear Parallel
To attach a 12-tooth pinion to a 4mm diameter flat tip DC motor shaft, a common method is to use a gear with a hub and a set screw. The set screw can secure the gear to the flat section of the shaft, ensuring proper alignment and stability. There are concerns about finding stainless steel gears specifically designed for flat tip shafts, as many available options may not fit this requirement. Some gears are designed with an opposite shape to accommodate flat shafts, which could be a viable solution. Proper gear selection is essential for effective power transmission in parallel shaft applications.
novato
Hi,
I have a DC motor with 4mm diameter shaft, flat tip.
How can I attach a 12 teeth pinion to this drive shaft?. I have been loking for pinions and gears on the web but they don't specify how are they attached to a shaft, as there are round shafts and flat tip shafts. Do I have to ask for gears with hub and set screw?
Any help would be very appreciated.
Novato
There are many ways to do it, one of the simplest would be a set screw in the gear's hub, like on this W.M.Berg gear:
http://www.wmberg.com/catalog/photos/B05B065.jpg
http://www.wmberg.com/catalog/productsearch.aspx?url=http://wmberg.smartcats.com/sc_app/default.asp
The set screw is a good option but, is there any stainless steel gear that matches a flat tip shaft like this?
Your question doesn't make a whole lot of sense. The flat is made for the set screw. Who/what are stanley steel gears?
Thank you. I have seen some gears that have an opposite shape for flat tip shafts.
PD: I'm sorry about the bad spelling.
Thread 'Physics of Stretch: What pressure does a band apply on a cylinder?'
Scenario 1 (figure 1) A continuous loop of elastic material is stretched around two metal bars. The top bar is attached to a load cell that reads force. The lower bar can be moved downwards to stretch the elastic material. The lower bar is moved downwards until the two bars are 1190mm apart, stretching the elastic material. The bars are 5mm thick, so the total internal loop length is 1200mm (1190mm + 5mm + 5mm). At this level of stretch, the load cell reads 45N tensile force. Key numbers...
After over 25 years of engineering, designing and analyzing bolted joints, I just learned this little fact. According to ASME B1.2, Gages and Gaging for Unified Inch Screw Threads: "The no-go gage should not pass over more than three complete turns when inserted into the internal thread of the product. " 3 turns seems like way to much. I have some really critical nuts that are of standard geometry (5/8"-11 UNC 3B) and have about 4.5 threads when you account for the chamfers on either...
