Square root of 4.1- do you have to use calculus?
10 replies · 3K views
Femme_physics
Square root of 4.1-- do you have to use calculus?
In order to solve square root of 4.1, is there a simple arithmetic method or do you have to use calculus and use that "tangent line approximation formula"?
I wonder how do calculators do it... does anybody know?
I'm assuming you by "tangent line approximation method" you mean Newton's method. What exactly is wrong with it?
I suppose if you wanted a more "elementary method", you could the following:
[tex] x_{n+1} = \frac{1}{2} (x_n + \frac{4.1}{x_n} )[/tex]
That sequence will converge to your square root, and it's an analog of Newton's method.
Oh, okay, I see the next topic in my book is Newton's method. Guess I should've read that first :shy:
Okay, I read Newton's method. Both methods don't give the exact results (to all sig fig). Do calculators give the exact result? I wonder.
Calculus textbook, of course! It's produced by the OpenU of my country (IL)
No, calculators don't give an exact result, in general. How could they, since they only display a finite number of digits? They use an approximation algorithm like the one described above.
[tex]\sqrt{4.1}= \frac{\sqrt{41}}{\sqrt{10}}[/tex]
Neither 41 nor 10 is a perfect square so their square roots are irrational. Further, they have no common factors so the ratio of [itex]\sqrt{41}[/itex] to [itex]\sqrt{10}[/itex] is irrational. It cannot be written as a finite decimal expansion nor as a ratio of integers (fraction). No, calculators do not give an exact result for a problem like that- the exact result cannot be written in any "place value" notation.
Note, however, that if the calculator displays n digits of the result, those n digits are the correct first n digits of the decimal expansion of the number. The approximative methods allow you to calculate the correct digits up to any precision you desire.
Thanks Halls, guys. That pretty much clears it up for me :)
