Square Root Rules for Fractions: x∈[3,∞)
7 replies · 4K views · last reply
Amer
[tex]\sqrt{\frac{x-3}{x}} = \frac{\sqrt{x-3}}{\sqrt{x}}[/tex]
that is not true for all x, it is true for [tex]x\in [3,\infty)[/tex]
I want to teach my students that the exponents distribute over fractions unless we have a case like that square root or any even root.
what do you think ?
Re: about square root
Generally for the case
$$\sqrt{\frac{a}{b}} $$ we require that
$$\frac{a}{b}\geq 0 $$ which means either
  • a $\geq$ 0,b>0
  • $a\leq 0$,b<0
For the first case we can state $$\sqrt{\frac{a}{b}}=\frac{\sqrt{a}}{\sqrt{b}} $$
What made me ask this question the website wolfarmalpha plot the function
[tex]f(x) = \frac{\sqrt{x-3}}{\sqrt{x}}[/tex]
although
[tex]f(-1) = \frac{\sqrt{-4}}{\sqrt{-2}}[/tex] which is not a real number
the domain of the function is [tex][3,\infty)[/tex]
f should start from x=3 to infinity, Am I right ?
  • Plot of the real and imaginary parts of sqrt(x-3)/sqrt(x) for x from -2 to 6; real part in blue, imaginary part in orange, with a vertical asymptote near x = 0 and both curves meeting at x = 3.
Wolfram gives the plot of the function in the complex plane , we have to add the condition that $x \geq 3$ to only focus on real part.
- - - Updated - - -
Unfortunately this is a real number [tex]f(-1) = \frac{\sqrt{-4}}{\sqrt{-2}} =\frac{2i}{\sqrt{2} i}=\sqrt{2}[/tex]
ZaidAlyafey's response shows that there is, in fact, a distinction between [math]\sqrt{\frac{x - 3}{x}}[/math] and [math]\frac{\sqrt{x - 3}}{\sqrt{x}}[/math]. What level are your students at? It might be better to sweep this particular kind of example under the rug.
-Dan
I see this as a domain issue. If we consider the inequality:
$$\frac{x-3}{x}\ge0$$
we find $x$ in:
$$(-\infty,0)\,\cup\,[3,\infty)$$
And over this domain, we may state:
$$\sqrt{\frac{x-3}{x}}=\frac{\sqrt{x-3}}{\sqrt{x}}$$
topsquark said:
ZaidAlyafey's response shows that there is, in fact, a distinction between [math]\sqrt{\frac{x - 3}{3}}[/math] and [math]\frac{\sqrt{x - 3}}{\sqrt{x}}[/math]. What level are your students at? It might be better to sweep this particular kind of example under the rug.
-Dan
They are high school students 11th class
- - - Updated - - -
we find $x$ in:
I think we should split it into two parts if x>=3
if x< 0
[tex]\sqrt{\frac{x-3}{x}} = \frac{\sqrt{3-x}}{\sqrt{-x}}[/tex]
right ?
if x< 0
right ?
That would indeed be a better approach, as this way there are no imaginary factors to divide out. (Yes).
