Find Steel Tubing Size for 4000lb Log Ramp - 8' Long
  • Thread starter Thread starter MB3
    Square Steel
The discussion focuses on determining the appropriate steel tubing size for constructing an 8-foot long ramp capable of supporting logs weighing 4000 lbs at angles between 25 and 38 degrees. The participant suggests that 1.5 x .125 tubing may be insufficient and emphasizes the importance of factors such as mass, wall thickness, and angle. Alternative materials, such as "I" beams, are proposed, and the need for adequate structural support is highlighted, particularly in relation to repositioning logs during milling operations.
  • Understanding of structural engineering principles related to load-bearing capacities
  • Familiarity with steel tubing specifications and their applications
  • Knowledge of milling processes and log handling techniques
  • Experience with welding equipment and fabrication methods
  • Research the load-bearing capacities of various steel tubing sizes and profiles
  • Explore the use of "I" beams versus steel tubing for ramp construction
  • Learn about log handling equipment and techniques for milling operations
  • Investigate design principles for creating truss-like structures in ramp design
This discussion is beneficial for engineers, fabricators, and sawmill operators involved in log handling and milling operations, particularly those looking to optimize ramp design for heavy loads.
MB3
I am making a ramps to load logs onto a portable sawmill. I would like to know the size steel tubing I need for logs weighing 4000 lbs. the ramps would be 8' long and at the following angles; never less than 25 degrees never more than 38 degrees. 1.5 x .125 tubing is available locally, but that does not seem to be big enough. Any help is appreciated.
length?
Mass of logs, length of travel, wall thickness of the rod, and angle are all important. Can you not use another profile - for example - "I" beam? The amount of work done is proportional to the distance the log is raised.
I was a sawyer for several years back in the 1960's. Never saw steel tubing like you describe used as part of end-dogging. We milled 20' bucked Quercus rubra logs, 36+" diameter - imported. We milled largely quartersawn 15/4 - air dried and planed to 12/4. We made church pews and furniture.
So I can tell what you are doing:
Will the logs roll up the incline, or are they to be dragged along the length? Unless things have changed radically, you are going to need lots of those (my current opinion) somewhat puny rods. If you are not milling log run, you have to reposition logs during the milling process and re-dog them in place. Log run also requires repositioning for some kinds of mills. So how does the mill hold the log during cutting?
Once you run logs through the mill you have the problem of getting them off there out of harms way, and then stickered (ventilated stacks), which means lifting as well.
So.
1. what exact rod stock are you planning on using?
2. How long do you need the rods to be?
3. Is this a one-man operation? If required, one man cannot usually reposition heavy logs easily and safely. Even with a pinch bar.
Do you have welding equipment or must it be a standard section?
It is the section of the ramp that makes the difference, it needs to be deeper near the middle like a truss.
Why use steel tube when you could use timber?
I run a portable 6" Lucas Mill. Out of interest, what type of mill do you have?
71K
18K
12K
11K
11K
13K
