Stabilize H2O2: Sodium Stanate & Phosphoric Acid
  • Thread starter Thread starter doctoxin
The stabilization of hydrogen peroxide (H2O2) can be effectively achieved using sodium stanate and phosphoric acid at concentrations of approximately 0.1% each in an 8% H2O2 solution. Even with these stabilizers, H2O2 will still degrade over time, with a 7.9% solution reducing to 7.1% over five years when stored properly in an opaque container. It is crucial to use a vented cap during storage to manage the off-gassing of oxygen. Additionally, when using sodium percarbonate as a hydrogen peroxide source, avoid using phosphoric acid for pH control due to potential violent reactions; instead, opt for citric or boric acid.
  • Understanding of hydrogen peroxide chemistry
  • Knowledge of chemical stabilization techniques
  • Familiarity with sodium stanate and phosphoric acid
  • Basic principles of solubility and pH management
  • Research the effects of sodium stanate and phosphoric acid on H2O2 stability
  • Learn about the decomposition process of hydrogen peroxide
  • Investigate alternative acids for pH control in chemical mixtures
  • Explore safe storage practices for hydrogen peroxide solutions
Chemists, laboratory technicians, and anyone involved in the handling and stabilization of hydrogen peroxide solutions will benefit from this discussion.
doctoxin
I happened to come to this site by chance. I was checking solubilities of a few compounds I am considering mixing and came across a thread where people were discussing sodium percarbonate and hydrogen peroxide. Someone mentioned about stabilization of the H2O2 but no one could remember what chemicals to use for that.
<< Mentor Note: Link to the old thread is added here >>
https://www.physicsforums.com/threads/h2o2-in-h20-stability.278442/
I have done this in the past and currently work with it now. You use both sodium stanate and phosphoric acid at about 0.1% for each in hydrogen peroxide that approaches 8%. At lower concentration the breakdown is much slower. Even with the stabilizers it will still break down.
My experience has shown me that a 7.9% hydrogen peroxide solution will break down to 7.1% over 5 years when it is stored properly in an opaque container. You also need to remember that during the break down there is continual off-gassing of oxygen (H2O2 breaks down to H2O) so you need to store it with a vented cap to relieve the pressure that builds up.
As for using sodium percarbonate as a source for hydrogen peroxide, good idea, I do it myself but be sure if you are mixing it with other compounds check your solubility and keep in mind that the other part of sp is Na-carbonate which will drive your pH up. Do not use the phosphoric acid to control the pH with the Na-percarbonate, it will react violently. Instead use citric acid or boric acid depending on your application.
Okay, that's my 2 cents for the day.
Likes berkeman
Chemistry news on Phys.org
Thanks doc, I did not know that. :smile:
I came.across a headline and read some of the article, so I was curious. Scientists discover that gold is a 'reactive metal' by accidentally creating a new material in the lab https://www.earth.com/news/discovery-that-gold-is-reactive-metal-by-creating-gold-hydride-in-lab-experiment/ From SLAC - A SLAC team unexpectedly formed gold hydride in an experiment that could pave the way for studying materials under extreme conditions like those found inside certain planets and stars undergoing...
10K
  • · Replies 21 ·
9K
