Standard PPM servo interface with matlab
8 replies · 6K views
Cyrus
I need some help here. I need to have a standard PPM servo interface with MATLAB so that I can give it a command in simulink and have a response.
I found this device, which eliminates the need to use PPM in simulink.
http://www.parallax.com/detail.asp?product_id=28823
Basically, it takes the servo command and converts it to a serial USB port. Now, I need to know how do I open this com port in simulink and get it to work? I am not an EE, and I don't know how to do this. I have used the com port once before in matlab, but not simulink.
Any help, PLEASE!?
-this is what happens when an ME takes an EE lab course. It hits the fan. :frown:
I had to help come up with a microcontroller for my senior design project, and being an ME I had no idea where to start. But, I will tell you I came out with a very robust design using Parallax products and talking to their technical support people who are very knowledgeable. I would definitely try calling tech support and see if they can help.
I called the guy on the phone. He says all I need to do is open a com port and send it serial information through a string with a ! and a carrage return.
Lets hope it works. I rush ordered one today. Should be here tomorrow. If I can't get this to work, I am in big trouble.
No, just matlab. Is dSpace an equivalent to Simulink?
You write your control mechanism in simulink (incl. filters, modulation etc.) and compile it in dSpace -- you can add nobs and buttons in a nice gui which controls your apparutus through the dSpace interface -- through BNC (sp?) cables.
Sorry for being a bit vague on the technicalities -- I've used it a lot but am not so clued up on the jargon.
@cyrusabdollahi
How do you try to connect Simulink to paralax motor?
Can this using microcontoller via serial port?
Regarding dSpace
Do you know how to use the Serial UART (RS232) in dSpace? I am trying to use a sensor which gives data for RS232 in ASCII format. I tried using Serial UART of dSpace but it gives numbers which don't make sense..
I have a 2-D modeling problem. I used Matlab pdetool to solve a 2-D axisymmetric problem. pdetool gives T (temperature) distribution and grad(T) distribution. What I need is the surface flux (in the norm) direction. My shape is irregular (like half of an egg shell). Matlab's quiver will not provide this. Is there a function somewhere that I can use to get the norm component of grad(T) generated by pdetool? Maybe I can use a function somewhere to calculate the norm direction first. This kind of problems must have been solved in some application areas already.
Thanks!
