Static and dynamic excited states
3 replies · 2K views
kelly0303
Hello! I am reading about excited levels in nuclei (I am mainly following Wong's nuclear physics book) and I am a bit confused about the nature of the excited states. In the one particle picture (mainly shell model) the excitation appears as static i.e. one nucleon moves from a certain orbital to another one and that's it. In the liquid drop model the excitation appears dynamic i.e. the energy leads to nucleus to vibrate or rotate. I am a bit confused if these 2 pictures are describing the same excitation levels, or they are two separate things? For example in molecules you have some "static" excitations (i.e. electronic excitations) and some "dynamic" ones (i.e. rotation and vibration). Is it the same here i.e. does the shell model describe static excitations and the liquid drop model describes dynamic ones, or they are the same ones just from 2 different perspectives? Basically when I see a diagram of a nucleus with energy levels (and spin and parity of each level), can any of these transitions (at least in principle) be described by both shell model and liquid drop model (of course one of them might be more adequate for a given nucleus), or each transition can be explain by only one of the two (I am aware that there are many other models out there, but I'd like to stick to these 2 for now). Thank you!
They are different excitations. You can have individual nucleons reaching higher energy levels but you can also have the whole nucleus deform (collective excitations/giant resonances).
Note that - just like for orbitals - these deformations don't need to have a state that changes in time.
Thank you for your reply! So experimentally, how can one figure out the type of excitation? For example an excitation with ##\lambda = 3##, which is an octupole deformation, is it because a nucleon changed its orbital angular momentum value by 3, or because the nucleus as a whole was having octupole oscillations? Or it can be both depending on the energy?
