Static Friction and Frictional Force Ranking Task
20 replies · 46K views
William2
Below are six crates at rest on level surfaces. The crates have different masses and the frictional coefficients [given as (μs, μk) ] between the crates and the surfaces differ. The same external force is applied to each crate, but none of the crates move.
Rank the crates on the basis of the frictional force acting on them.
Rank from largest to smallest. To rank items as equivalent, overlap them.
Items:
(mass in kg, μs, μk)
A. 250, 0.2, 0.1
B. 1500, 0.3, 0.1
C. 500, 0.6, 0.3
D. 750, 0.6, 0.5
E. 600, 0.8, 0.5
F. 750, 0.4, 0.3
fs ≤ μs * m * g
I used the equation fs = μs * m* g and got the answer wrong. Now I am just completely confused. Any help will be appreciated, thanks.
Discussion
William2 said:
fs ≤ μs * m * g
Note the less than or equal sign. The static force of friction could be less than μs*m *g. So, you'll need to bring in another idea to determine what the actual force of friction would be for each block. Hint: Newton's 2nd law.
F=ma
there is no acceleration because the crates do not move, correct? so force would be 0 for all of them?
still a little confused.
Ok, sooo
F - μkmg = m * a
there is no acceleration so
F = μkmg
So am I supposed to use μk instead of μs?
No, there is not kinetic friction in this problem since the blocks don't slide. You don't need to use any specific formula for friction. If I push horizontally on a block sitting on a horizontal surface with 5 N of force and it doesn't move, what is the value of the friction force?
5 N.
how would I figure out the horizontal force in this case?
is this equation correct?
F - μs(m * g) = 0 ; where F is the horizontal force
William2 said:
5 N.
Right, 5N. That makes the net force zero which agrees with the second law since we know a = 0.
In your problem, you don't need to figure out the horizontal applied force. Whatever it is, it's the same applied force for each crate. So, how would the friction forces compare for the various crates? (Again, μs*m * g is not relevant here since it represents only the maximum possible static friction force and you cannot assume that the forces of friction are at the maximum value.)
so...
would it simply be ranked based on the static frictional coefficient?
the only other known variable is mass.
Let F represent the applied force (assumed horizontal) and let fs represent the friction force. How would you express the net horizontal force using these symbols?
Net Force = F - fs
i think
TSny said:
Good. What does the net force have to equal according to the 2nd law?
it has to equal ma
so... F - fs = m * a
TSny said:
Yes. And what is the value of the acceleration for the crates?
0, i think.
a = F/m ; and net Force, F, is 0
Well, we know a = 0 because we are told that the crates don't move. So, if a = 0, what does the formula F - fs = ma tell you about the amount of friction force?
if a = 0 , then F = fs ; which was already determined
this seems like a loop to me
OMG, WOW!
IT WAS SO EASY! They are all the same?!
I LOVE YOU!
Since all blocks are not moving, the frictional force equal to applied force.
The static frictional force is not constant from zero to maximum μs.
Thus all the frictional forces are equal.
