Static Point in de Sitter-Schwarzschild Spacetime
4 replies · 2K views · last reply
timmdeeg
In de Sitter-Schwarzschild spacetime things close to the black hole are falling towards it whereas in greater distance they are receding. So there should be a certain (unstable) ##r##-coordinate, where things are static. The de Sitter-Schwarzschild metric has according to Wikipedia
https://en.wikipedia.org/wiki/De_Sitter–Schwarzschild_metric
2 solutions:
##f(r)=1-2M/r##
##f(r)=1-\Lambda*r^2##
Equating yields ##r=(2M/\Lambda)^{1/3}##
Is this the wanted static r-coordinate? Heuristically it seems to make sense, r increases with increasing ##M## and decreases with increasing ##\Lambda##.
But is this correct? Please advise.
timmdeeg said:
2 solutions
No, one solution with two extra terms in ##f(r)##, i.e., the superposition of the two individual solutions. The correct formula is ##f(r) = 1 - 2M / r - \Lambda r^2 / 3##. (Note the factor of ##3## in the ##\Lambda## term; the Wikipedia article is a little misleading since it fails to include that.)
timmdeeg said:
Equating
That's not how you find the static ##r## coordinate. You find it by looking for the value of ##r## for which the proper acceleration of a worldline with constant ##r## is zero. That gives a value that is close to, but not the same as, the one you derived. See here:
https://www.physicsforums.com/threa...ween-two-spherical-shells.989533/post-6347791
Note that the ##A## in that post is ##\Lambda / 3##.
Ok, got it, so zero proper acceleration of this timelike geodesic is the correct criterion.
Then with ##A=\Lambda/3## the correct result is
##r=(3M/\Lambda)^\frac{1}{3}##
Its by a factor 2 different from what results by equating the two extra terms. :rolleyes:
As always I appreciate your explanation, thanks.
With the exponent fixed (it should be ##\frac{1}{3}##, not ##\frac{1}{1/3}##), yes.
A factor of ##2^\frac{1}{3}##.
Indeed, fixed.
Yes, my fault.
