artis
- 1,479
- 976
From what I know accelerators that use cavities like LHC for example pass the protons multiple times around in order for the cavities to accelerate them at each pass to a higher energy, since they can't accelerate the protons to an energy high enough with just one pass.
So the protons pass through the same potential gradient but multiple times gaining energy each time if what I get is true. The cavities used for this synchrotron action are RF powered cavities
If this is so then I have an obvious question, why can't a static potetial straight or circular accelerator that uses a static DC potential do the same?
I read that static accelerators are limited by their breakdown voltage , yes sure but can't one just use a certain voltage and then have multiple static cavities/capacitors which are arranged one after another with some distance in between?I guess what I'm asking is can the same potential difference (100kV for example) be repeated again and again and the proton exiting from each previous accelerating gap would have a velocity which would be increased again by each next gap?Or is the reason to this that in RF cavities the proton arrival is timed with the field such that the field is in phase and accelerates them but when they have already entered the cavity while in a static potential cavity there would be a sort of stray field which would first somewhat decrease the speed of the arriving protons before increasing it?
