STATICS couples problem (I solved it but it doesnt make sense)
  • Thread starter Thread starter Chubigans
    Statics
The discussion revolves around a statics problem involving couples and moments in three-dimensional space. Participants are attempting to solve for forces F1 and F2 based on given conditions and are experiencing confusion regarding the application of the cross product and the resultant moments.
  • Homework-related
  • One participant presents a calculation for the moments generated by two forces, indicating a discrepancy in the x-component of the resultant moment.
  • Another participant suggests breaking the couple into components about the x and y axes to simplify the problem.
  • Questions are raised about the directions of forces F1 and F2, with uncertainty about whether they align with the x or y axes.
  • A later reply acknowledges that F1 produces a counterclockwise torque about the z-axis, which complicates achieving a zero sum of moments.
  • Concerns are expressed about the validity of the textbook answers for F1 and F2, with one participant seeking verification of their calculations.
  • Another participant offers to compare answers to verify correctness.
  • One participant expresses frustration and uncertainty about the problem's feasibility, having already contacted their professor regarding the issue.
Participants do not reach a consensus on the correct values for F1 and F2, and there are multiple competing views regarding the calculations and interpretations of the problem.
There are unresolved assumptions regarding the diagram and the definitions of the forces involved. The discussion reflects uncertainty about the application of the cross product in three dimensions and the resulting moments.
Chubigans
M = r x F, where r is "a vector directed from the line of action of one of the forces to the line of action of any other force"
Well, for the 250 lb couple the r = {3i - 4j - 2k{, F = 250 {3/5i - 4/5j}
M = {-400i - 300j} (I verified this by taking the moments individually)
For F1, r = 3i and F = fyj
so M = 3Fy*k
For F2, r = {-2k} F = {fxi} so M = {-2Fxj}
When we sum the moments, we get {-400i -300 - 2Fxj + 3Fyk }
The x component can never equal zero!
There are two possibilities: I'm misreading the diagram, I'm missing something entirely, or I don't understand the couples idea of getting the vector r between two forces. Please help, I've been doing this for over 5 hours now.
so M = 3Fy*k
You deserve a break after 5 hours! What I see as the problem, is that you are trying to use the cross product rule for determining moments, and in 3D, that is one bear of a problem. Instead, you should break up the given couple (250*2 = 500 ft-lbs) into its components about the x and y axes. Once you do that, try summing moments about the x and y axes separately. That will simplify your time spent to 5 minutes, if you do it right:wink:
But Jay i have a question, What direction is F2 in? Is it entirely in the X direction? And what about F1? Is it entirely in the negative y direction? This homework is due tomorrow! It doesn't make any sense! Please help me solve it!
Wow, sorry, you are quite sharp after 5 hours, I looked at the problem quickly, and missed the fact that as shown, +/-F1 is directed along the y axis, and produces a ccw torque about the vertical z axis. Since the other torques do not have any torques or torque components about the z axis, there is no way the sum can be 0, so you are 100% correct. I guess you can state that result in your homework, and maybe get some bonus points. :rolleyes:
Can somebody verify this!? I'm not about to turn in homework questioning my textbook! The answers in the back are F2 = 200 and F1 = 150. It seems impossible. help?
Chubigans: I worked the problem quickly, and got an answer. Post your answer, and then I can tell you whether or not your answer matches what I got.
My answer was sum of moments = {-400i + 300j - 2F2j + 3F1k} which never equals 0
I already emailed my professor telling him it was impossible, hope i don't look like a dumbass!
But that doesn't answer the given question, which is asking for F1 and F2. What is your answer for F1 and F2?
why not? If you're wrong, so be it, and move on to the next problem; but if you're right...
10K
16K
