Statics: find tension/wrap angle for pulley
3 replies · 3K views
SoylentBlue
Given: T(sub-B) plus T(sub-B) prime = 36. Both T(sub-C) values are 0. T (sub-D) =36 and T (sub-D) prime = 12. Find values of T (sub-B) and T (sub-B) prime[/B]
OK, so we need to find the wrap angle, which should be 180 + 30 -22, which comes to 188 degrees, which is 1.04 pi radians.
Then: T (tightside)/T (slackside) = e raised to wrap angle (in radians)
This yields a T (tightside)/T (slackside) of 2.84.
The book shows this ratio as 3.
Also, confused: the values of T (sub-D) are in the same ratio (3 to 1) yet their wrap value is clearly 180 degrees or 1 pi[/B]
Can someone point me in the right direction? Thank you.
This is a balance of moments problem, not a belt friction problem. But, in any event, in your equation for the ratio of the tensions, you left out the coefficient of friction.
Chet
Oh, so this is just a lever-arm problem? If we look at T (sub-D), it exerts a torque of (6 in)(36Lbs)=216 in-LB on the axle. Therefore, the tightside of the belt around pulley B, which is T (sub-B), must also exert 216 in-LB of force on the axle. We know its lever arm is 8 in, so the force must be 27LB. Is this the correct logic to apply here?
Thank you for helping...I am trying to wade through this statics course by myself, so I don't have access to professors or even other students to ask questions or debate logic.
No. You need to include in the moment balance all four of these: TB, TB', TD, and TD'.
Chet
